ᐅ Which screws can improve the stability of Ikea PLATSA units?
Created on: 16 Oct 2016 08:12
anriga
anriga
16 Oct 2016 08:12
I’m planning to reinforce my Ikea Platsa cabinet, as the standard fasteners don’t seem quite sturdy enough. My specific question is: What alternatives to the screws included in the IKEA set can be used with PLATSA to improve the stability of the structure? I am particularly interested in screws that are better suited in terms of diameter, material, and thread design, without making the assembly more difficult.
I would also like to know if there are specialized types of screws that work especially well for joining the panels together, and if you have any advice on choosing the screw length to avoid damaging the material while still achieving maximum holding strength.
I would appreciate any experiences or recommendations you might have!
Sinzar
16 Oct 2016 08:18
I would definitely choose screws with a larger diameter, around M6 instead of the usual M4 or M5, to achieve greater stability. It is important that the screw material is steel or better. Longer screws help, but not too long, otherwise the wood may split.
LENNAU
16 Oct 2016 09:03
Hello anriga,
your question touches on an important aspect of PLATSA furniture: stability.
Basically, Ikea uses chipboard screws and cylindrical wooden dowels for PLATSA, which are generally sufficient for their intended purpose. However, if you want to achieve better stability, there are a few things to keep in mind:
- Hardened steel screws are recommended because they do not give way as easily.
- One option is self-tapping chipboard screws with a coarser thread, as they provide better grip in the wood.
- Screws with a washer head can distribute clamping force more effectively.
- Regarding length, make sure the screws engage at least 40mm (1.5 inches) into the mating part but are not too long to avoid damaging the back panel.
Additionally, applying wood glue in the dowel holes can significantly increase stability.
If you like, I can also recommend specific screw dimensions.
SUPE2
16 Oct 2016 09:10
I used M6 stainless steel screws for my PLATSA cabinet system to improve corrosion resistance. This makes everything hold much more securely, especially the connections between the side panels.
glamo8
16 Oct 2016 09:37
You can use screws other than the original ones, but be careful: the threads must be designed for particleboard, otherwise the material will tear. The best choice is coarse-thread particleboard screws with a diameter of about 4–5 mm (0.16–0.20 inches).
Joshbe
16 Oct 2016 10:21
LENNAU schrieb:
Additionally, using wood glue in the dowel holes can significantly increase stability.
This is an important point. In addition to higher-quality screws, I recommend:
- Screws made of hardened steel with fine chipboard threads
- Screw length of at least 45–50 mm (1.8–2.0 inches) for a secure hold
- Countersunk screws, so they sit flush with the surface
Also: In PLATSA systems, the panels are usually particleboard with a melamine coating, so drill holes precisely to avoid damage caused by screws that are too thick.
A combination of better screws and glue significantly improves stability.
