ᐅ Which screws can improve the stability of Ikea PLATSA units?
Created on: 16 Oct 2016 08:12
anriga
I’m planning to reinforce my Ikea Platsa cabinet, as the standard fasteners don’t seem quite sturdy enough. My specific question is: What alternatives to the screws included in the IKEA set can be used with PLATSA to improve the stability of the structure? I am particularly interested in screws that are better suited in terms of diameter, material, and thread design, without making the assembly more difficult.
I would also like to know if there are specialized types of screws that work especially well for joining the panels together, and if you have any advice on choosing the screw length to avoid damaging the material while still achieving maximum holding strength.
I would appreciate any experiences or recommendations you might have!
REOHEINRIC
17 Oct 2016 07:29
When working with chipboard, it is essential to use screws that have a thread profile specifically designed for particleboard. Standard wood screws do not grip as well in this material.
Additionally, countersunk screws with a wide bearing surface are ideal to distribute the pressure on the boards evenly. Alternatively, you can also consider special furniture connector screws that allow for better tightening.
The length of the screws should be chosen so that they penetrate the boards by at least 10 to 15 mm (0.4 to 0.6 inches), meaning a shank length of about 40-50 mm (1.6 to 2 inches). When working with laminated boards, be careful not to overtighten in order to avoid cracking.
anriga
17 Oct 2016 08:13
Joshbe schrieb:
Also: In PLATSA systems, the panels are usually particleboard with a melamine coating, so drill holes carefully to avoid damage caused by screws that are too thick.
Thanks for the tips. The melamine coating is important; I definitely don’t want to damage that.
REOHEINRIC schrieb:
When working with PLATSA, you should definitely use screws with a thread profile specifically designed for particleboard. Regular wood screws don’t hold as well here.
That confirms what I suspected. Does anyone have specific recommendations for manufacturers or sizes of particleboard screws that have proven particularly reliable with PLATSA?
Also, what about alternatives to wood screws, such as specialized furniture fasteners or other accessories that can be used to increase stability?
farna7
17 Oct 2016 10:48
To improve the stability of PLATSA, I recommend considering the following points in addition to replacing the screws:
- Do not overtighten the screws, as the melamine coating can be damaged.
- Use wood glue in the dowel holes to strengthen the joints.
- Screws should have a diameter of 4-5 mm (0.16-0.2 inches) and be suitable for particleboard.
- Alternatively, metal fasteners or brackets from a hardware store can provide additional support.
The combination of better screws and glue usually leads to significant improvements.
Jan31
18 Oct 2016 14:22
If you want to maximize stability, consider screws with full threading and heat treatment. These are significantly more durable than standard chipboard screws.
However, be careful not to use screws that are too thick, as this can cause the chipboard to split. A diameter of 4.5 mm (about 3/16 inch) with a length of approximately 50 mm (2 inches) is optimal.
Additionally, using small metal brackets to reinforce the joints is recommended, especially at the corners.
