ᐅ Are there IKEA PLATSA models with particularly durable shelves?
Created on: 1 Dec 2021 08:34
finbar36
finbar36
1 Dec 2021 08:34
Hello everyone, I am currently looking into the IKEA Platsa system and plan to build a shelf that can carry as much weight as possible. Therefore, my question is: Are there any shelves within the different PLATSA models or variants designed to support particularly heavy loads? I am not looking for standard shelves but ones specifically designed for heavier items – ideally with information on maximum load capacity or special materials or reinforcements. Who has experience with this or can offer recommendations?
emmett
1 Dec 2021 09:12
The PLATSA shelves from the basic model are not designed for very heavy loads by default. If you want to store heavy items, you should either reinforce the shelves or consider using a different IKEA system that offers more durable shelves.
Cecilera66
1 Dec 2021 09:46
PLATSA does not offer any special "extra strong" shelves. The material is usually particleboard with a foil covering. For areas with higher loads, additional reinforcement from below is recommended, for example with metal brackets.
finbar36
1 Dec 2021 11:03
Cecilera66 schrieb:
There are no special "extra strong" shelves available for PLATSA.
Thank you, that confirms my suspicion. Does IKEA officially provide technical data regarding the load capacity of the standard PLATSA shelves? Unfortunately, I couldn’t find reliable information in the product details. Maybe someone has a datasheet or experience-based values on how many kilograms can safely be placed on a single shelf?
letar
1 Dec 2021 12:27
The official load capacity information for the PLATSA shelves is indeed quite vague. Typically, load capacities of around 15-20 kg (33-44 lbs) per shelf are indicated, assuming the load is evenly distributed. Higher loads require additional reinforcement measures, as the particleboard can otherwise sag. The width and depth of the shelf are also crucial, since larger spans are less stable.
Rashadmeo
1 Dec 2021 13:18
Hey, a few months ago I used a PLATSA shelf as a shoe cabinet and placed quite a few shoes on it – had no issues with sagging shelves! 🙂 However, I didn’t put more than 10 kg (22 lbs) on each shelf. For heavier items, I would still be cautious and maybe consider wooden or metal shelves.
