Hello everyone, I am currently planning the assembly of a Pax wardrobe from IKEA and want to avoid common mistakes that often occur during the build. I am particularly interested in issues caused by carelessness or misinterpretation of the assembly instructions, such as incorrect positioning of side panels, inaccurate alignment of the rails, or difficulties when mounting the wardrobe doors. It would also be helpful if you could share how errors during the installation of drawers and clothes rails affect the final result and what to keep in mind to prevent functional problems later on. So: what are common mistakes to avoid when assembling a Pax wardrobe to ensure a sturdy, functional, and visually appealing piece of furniture?
A very important topic, as the Pax wardrobe is prone to errors due to its modular design and the relatively large number of parts. The most common mistakes include:
- Inaccurate alignment of the side panels, which makes the frame structure unstable.
- Incorrect assembly or swapping of the shelves, affecting later positioning.
- Insufficient fastening of the back panel, which significantly impacts stability.
- Mistakes when installing the rail systems for drawers or doors, leading to sticking or blocking functions.
My advice: Use a spirit level and check every step, even if the instructions seem simple, and be sure to use all the specified screws and dowels.
I often help friends with assembly and have noticed that inexperienced people often underestimate how important the precise alignment of the cabinet frame is. A misaligned part later causes problems when hanging the doors.
Furthermore, I recommend assembling the furniture with at least two people, as this makes handling larger parts easier and reduces errors caused by instability during assembly.
cecile65 schrieb:I can only confirm that. The back panel is a key stability component, even if it appears insignificant visually.
The back panel is often only loosely attached or completely omitted. This significantly weakens the cabinet.
One important aspect that is often overlooked: the cabinet feet or height adjustment. If these are not properly aligned, the cabinet will stand unevenly, which can cause stresses that negatively affect the drawers and doors.
Also, ensure that the drawer slides are installed precisely parallel to each other, as this prevents jamming or sticking later on.
I recommend allowing time for fine-tuning and adjustment of the doors and, if necessary, asking a second person for help.
barEsperan17 Feb 2021 09:22One common mistake I often see is not driving the screws deep enough or tightening them too much, which causes the wood to split. It is important to use a torque wrench or at least work carefully. The assembly sequence is also crucial, for example, building the frame first and then attaching the back panel.
