ᐅ How do I check the stability of the Pax wardrobe after assembly?
Created on: 25 Sep 2023 08:37
Steffen31
Steffen31
25 Sep 2023 08:37
I just assembled my new Pax wardrobe and want to make sure it is truly stable after assembly, with no risk of tipping or wobbling. The assembly instructions are okay, but I didn’t find any specific advice on how to check its stability.
My question to you is: What is the best way to test the stability of a Pax wardrobe on site after assembly?
I am particularly interested in steps I can take right there without having to use extra tools or specialized measuring equipment to detect twisting, tipping risk, or loose fastenings.
Are there any tried-and-true routines or tests you can recommend?
Thank you in advance!
tutan
25 Sep 2023 09:05
Hey Steffen31,
first of all, congratulations on your new wardrobe! 👍 Checking its stability isn’t as complicated as it seems. So, once you’ve assembled everything, do the following:
- Try gently pushing the wardrobe at different points. If it wobbles, something might not be fitted properly.
- Check if all screws are tightened, especially those on the back panel.
- Make sure the wardrobe is securely attached to the wall. Wall mounting is really important for the Pax system.
Take your time with this, and you’ll quickly notice if anything feels loose. If the wardrobe stands firm and without any noise, you’ve done everything right. 😉
Lucien
25 Sep 2023 09:34
Additional information:
The stability check of a Pax wardrobe after assembly should be carried out systematically. Here is a precise procedure:
- Check all connection points: screws, dowels, and brackets must be tightly fastened.
- Inspect the back panel: it acts as a load-bearing element and provides lateral and torsional stability. The back panel must be complete and sit flush.
- Wall attachment: the wardrobe should be securely and properly aligned to the wall using the supplied mounting brackets.
- Load test: after visual inspections are complete, gentle shaking of the upper edges can help identify any potential instability.
For non-professionals, the back panel and wall attachment are particularly important.
Matthewt48
25 Sep 2023 10:11
Hello Steffen31,
I also had initial concerns about the stability of my Pax wardrobe. It is important that after assembling it, you check the following points:
- Are all screws tightened evenly without over-tightening the parts?
- Does the back panel lie flat? Sometimes an uneven installation causes stress that eventually leads to wobbling.
- Have you secured the wardrobe to the wall? Wall mounting is mandatory because otherwise, the wardrobe can easily tip over.
My tip: After assembly, stand in front of the wardrobe and gently press on both sides with your hands. If you feel any wobbling or hear creaking, check the fastenings again.
If you have any questions, I’m happy to help!
kaubi
25 Sep 2023 11:03
Hello Steffen31,
I like to go into detail, so here is a comprehensive guide to checking the stability of your Pax wardrobe:
1. Check the correct installation of the back panel:
- It must be fully fitted and carefully fastened with small nails or screws.
- Make sure no parts of the back panel are bent or warped, as this creates weak points.
2. Inspect the screws:
- Use a Phillips screwdriver or a cordless drill with torque control to avoid over-tightening or leaving screws too loose.
3. Check the floor levelness:
- An uneven floor can cause the wardrobe to wobble. Use a spirit level or place small felt pads underneath.
4. Install wall fixings:
- Especially for taller Pax wardrobes, secure anchoring to the wall is necessary.
- Ensure the wall plugs are suitable for your wall type (solid, drywall, etc.).
5. Tilt test:
- Apply gentle but firm pressure to the top edge of the wardrobe to check for weaknesses.
Can you tell me which back panel you installed and what the floor surface is like?
Steffen31
25 Sep 2023 11:47
kaubi schrieb:
Can you say which back panel you installed and what the floor surface is like?
Thanks for the detailed description! The back panel is a thin MDF board, as specified in the instructions. The floor is laminate and fairly level, at least it appears that way. Unfortunately, I didn’t have a spirit level on hand, but a small square fits well.
I have planned wall fixings but haven’t installed them yet because I wanted to test the stability first. Do you think it’s too risky without securing it to the wall?
