ᐅ How do I properly install Ikea Pax wardrobes on a sloped ceiling?
Created on: 3 May 2022 08:12
Timokau
I am currently facing the challenge of installing an Ikea Pax wardrobe under a sloped ceiling and would like to ask about proven methods for this. The main concern is how to properly adjust the side panels and the back panel to fit the slope so that the wardrobe stands stable without wobbling or looking awkward.
What experiences do you have with assembling the Pax under sloped ceilings? Are there any special tips for adjusting the measurements, fitting the doors, and securing the unit to the wall?
I would appreciate detailed advice, including recommendations on tools or assembly steps that should definitely be followed.
Thank you in advance to everyone who shares their expertise!
Repar
3 May 2022 11:03
First, saw the side panels to fit the slope. Attach the back wall in several sections. Doors can be shortened or left open at the top if needed. Always secure screws into the wall.
Timokau
3 May 2022 11:45
Thanks for the quick responses so far!
@zarlu: I understand the point about custom-made furniture, but unfortunately the budget is tight and Pax otherwise offers enough storage space. Custom furniture obviously looks better aesthetically, but functionality comes first here.
@sarlo, @letar: Your advice regarding the backs and wall mountings is very helpful. Do you think it’s possible to use regular chipboard panels as individual elements for the back, as long as they are securely fixed?
How does this affect the stability compared to the original Pax back panel?
Thanks also for the tip about the bevel gauge; I’ll make sure to get one.
Are there any other tips on what to particularly watch out for when attaching to the wall, especially if the wall isn’t perfectly vertical but slightly angled?
sarlo
3 May 2022 12:14
Timokau schrieb:
Do you think it’s possible to use regular particle boards as individual panels for the back wall, as long as they are securely fastened?
Yes, that works well. Make sure the thickness is sufficient (at least 8 mm (0.3 inches)) and that fastening is straightforward (screws or brackets). In terms of stability, it’s comparable because the back wall in Pax mainly serves to stiffen the structure.
Timokau schrieb:
Are there any special considerations for fastening to the wall, especially if the wall is not completely vertical but slightly angled?
In that case, it is important to choose anchors and screws that reach the load-bearing structure. For angled wall surfaces, adjustable brackets or special mounting brackets can help to properly align the cabinet.
When in doubt, it’s better to use longer screws and adjust the distance to the cabinet with washers.
theo63
3 May 2022 12:52
It is interesting that almost everyone here assumes that the Pax wardrobe should be used as a standard module despite the sloped ceiling.
zarlu schrieb:
Why not opt for a custom-made solution instead? Ikea’s assembly instructions are designed for right angles – it simply can’t be optimal.
This is a key point. Trying to adapt a system intended for regular rooms to fit a sloped ceiling inevitably leads to compromises.
Using particleboard as a back panel replaces the original, but it lacks the original connection system and precise fit – which can quickly affect the overall appearance and stability.
Therefore, it is important to carefully weigh whether to prioritize flexibility at any cost or to lean toward a tailor-made solution that is more sustainable and structurally secure, even if it requires more effort.
Timokau
3 May 2022 13:34
Good point, theo63. I agree to some extent but want to approach this with a certain pragmatism for now. My main question regarding installation on a sloped ceiling is whether you have any specific tips or experience on how to best adapt the original Pax components (straight parts: side panels, back panel, doors) to the sloped roof shape without compromising stability.
How do you properly redirect the back panel when it is installed in sections? Are longer screws in the corners sufficient, or is it better to use additional brackets and braces?
Also, does anyone have recommendations on how to shorten or modify the doors so that they still function properly?
letar
3 May 2022 14:05
Timokau schrieb:
How do you properly turn the back panel when installing it in sections?
The back panel sections must lie flush and be secured at the joints with brackets or metal connectors. This creates a stable surface unit that ties the side walls together.
Timokau schrieb:
Are longer screws in the corners sufficient, or is it better to use additional brackets and reinforcements?
Longer screws alone are rarely enough. Use special mounting brackets at critical points to distribute the loads.
Timokau schrieb:
Does anyone have recommendations on how to shorten or modify doors so they still function properly?
Doors can be shortened using a router or jigsaw. Be sure to also adjust or reposition the hinges and guide rails accordingly. Alternatively, sliding doors offer more flexibility for height adjustments.
