ᐅ Is there a way to extend the Pax wardrobe by adding a narrow side panel?
Created on: 3 Jun 2020 16:23
Neo45
Hello everyone, I am considering expanding my IKEA Pax wardrobe by adding an extra narrow side panel. Specifically, I am interested in whether there is a practical way to modify the wardrobe so that I can attach either a very narrow side wall or a slim element to the existing basic structure, in order to gain more storage space in a limited room situation. My idea is whether such an extension can be achieved, for example, with special connectors, additional side panels, or custom-made parts, without significantly compromising stability or appearance. Has anyone had experience with the best way to do this, or are there official IKEA modules or replacement parts available for this purpose? I would appreciate any tips or recommendations. Thank you!
vincent46 schrieb:
I decided on a custom-made wooden panel, which I fixed in place using clamps and angle brackets. That sounds interesting; that’s exactly the kind of solution I had in mind. Could you explain how you attached the panel? Did you do this on the inside or outside? Did you encounter any issues with surface damage or alignment?
nanidra schrieb:
Maybe a screw connection or wooden panel is a nice idea, but that’s more of a DIY approach. I agree with that to some extent, but my hope is to extend the system’s capabilities reasonably through good craftsmanship without taking excessive risks.
I’m looking forward to more advice, especially regarding which materials you think work best for the narrow side.
The idea of adding an extra wooden or MDF panel to the narrow side is, in my opinion, the best practical solution currently available. My recommendation would be:
- Cut the panel to the same thickness as the existing side wall (usually 16mm (0.63 inches))
- Attach it on the inside of the side wall using flat connectors or small brackets to keep it visually neat
- Adjust the finish of the panel first to match the color (either paint it yourself or use a veneer)
- When installing, make sure it is perfectly vertical to avoid door alignment issues
This way, the unit gains additional storage space without needing a complete rebuild of the cabinet.
Matthewt485 Jun 2020 07:14Hello Neo45 and everyone reading,
to provide a more detailed perspective on this topic: The Pax wardrobe was originally designed as a modular system with specific standard widths. There is no IKEA component for a narrow extension on the side because the manufacturer focuses on simplicity and interchangeability.
However, if you want to push the boundaries, you can use narrow strips or panels as an add-on and secure them with connectors such as flat connectors, corner braces, or even perforated metal strips. In doing so, I would recommend:
- Using high-quality screws and brackets
- Ensuring that the total weight does not overload the wardrobe frame
- Checking the precise alignment with a spirit level and protractor
- Considering additional supports or reinforcements, especially if you plan to place heavy clothing or accessories on the extension
If you have no experience with woodworking, I advise seeking professional advice or assistance. You can mostly maintain both the interior functionality and the appearance to match.
I hope this helps you move forward.
V
vincent465 Jun 2020 11:38Neo45 schrieb:
Could you describe how you fastened the panel?Sure! I used metal brackets on the inside edge, which I fixed to the frame with screws and also screwed through the panel. It’s important that the brackets aren’t too large so they don’t interfere with the shelves. I also painted the panel beforehand to visually match the white Pax. There were hardly any issues with the installation—just mark carefully and then screw in slowly to ensure everything fits precisely.Of course, this isn’t as elegant as an official solution, but it’s practical and sturdy enough for me. Hope this helps with your project!
