Hello everyone, I am currently planning the assembly of a Pax wardrobe from IKEA and want to avoid common mistakes that often occur during the build. I am particularly interested in issues caused by carelessness or misinterpretation of the assembly instructions, such as incorrect positioning of side panels, inaccurate alignment of the rails, or difficulties when mounting the wardrobe doors. It would also be helpful if you could share how errors during the installation of drawers and clothes rails affect the final result and what to keep in mind to prevent functional problems later on. So: what are common mistakes to avoid when assembling a Pax wardrobe to ensure a sturdy, functional, and visually appealing piece of furniture?
In summary, the biggest mistakes are:
- Neglecting alignment: unevenness in adjustable feet and side panels
- Incorrect installation of the back panel: insufficient fixing
- Improper installation of drawer slides and doors, e.g., not aligned according to assembly instructions
- Incorrect use of fittings and anchors due to wrong positioning or incomplete tightening
My advice: The IKEA assembly video can complement the manual and clarify some technical details. Also, using a square and a spirit level helps ensure permanent straightness.
Additionally, when installing the closet rods, it is important to ensure they are mounted to support the correct load, meaning they must be securely fixed at the designated points. A loose attachment can cause the rods to tilt and may lead to permanent damage. It is also important to carefully check the specifications of the mounting hardware, as these can vary depending on the model, and incorrect installation is often only noticed much later.
Overall, I recommend not rushing and working carefully step by step according to the instructions.
RENMA schrieb:I fully agree; this is a crucial point that ensures stability and durability.
- Incorrect use of fittings and anchors due to improper placement or incomplete tightening
