ᐅ Which Ikea Pax wardrobes are suitable for walk-in closets?
Created on: 7 Jul 2021 08:37
nidilu
I am currently planning to set up a walk-in closet and am very interested in the Ikea Pax wardrobe series. Since the options with Pax are very diverse, especially regarding different widths, heights, depths, and interior configurations, I have the following question: Which Ikea Pax wardrobes are particularly suitable for walk-in closets?
I am especially concerned with aspects such as:
- optimal dimensions for small to medium-sized walk-in closets
- flexibility in interior design, e.g., for shoes, hanging clothes, drawers
- stability and quality of workmanship with frequent use
- sensible combinations, especially when the closet space can be freely planned
If anyone has experience with specific models or combinations, or can offer helpful tips for planning and selection, I would greatly appreciate your insights!
Marlenepa
7 Jul 2021 14:33
Hello nidilu,
your project sounds great! When planning the interior layout, keep in mind that Ikea offers many accessories for the Pax wardrobes:
- Drawers in various heights
- Shelves
- Clothes rails
- Shoe pull-outs
- Hanging devices for ties or belts
I chose a depth of 75 cm (30 inches) because I have many hanging clothes. I purchased them at a height of 236 cm (93 inches) to maximize storage space.
It’s important to think about usage in advance: store daily clothes differently from those worn rarely.
For walk-in closets, doors are not necessary; you can design them as open spaces – this saves room and provides better overview. However, stability of the wardrobes should be ensured, which works well with Pax wardrobes due to their sturdy back panel.
Karsten45
7 Jul 2021 15:12
I would like to give a small warning about 100 cm (40 inches) wide Pax wardrobes in walk-in closets. They are often too bulky and not ideal for walk-in solutions. Wardrobes that are 75 cm (30 inches) wide are more flexible and easier to design.
Personally, I really like open Pax systems with a depth of 75 cm (30 inches) because everything is visible and easily accessible. You can also experiment very well with different elements – shelves, drawers, hanging rods.
Marlenepa schrieb:
For walk-in closets, doors are not necessary; you can keep them open – this saves space and improves visibility.
This matches my experience exactly. If the wardrobe back panel is sturdy, the modules hold together very well even without doors.
benfa
7 Jul 2021 16:23
I think the Pax series is sometimes treated a bit too uncritically here. Yes, it is versatile, but for walk-in closets, questions arise regarding the necessary stability, noise generation, and long-term durability.
Karsten45 schrieb:
If the back panel is stable, the modules hold together very well even without doors.
In my experience, the back panel alone is often not sufficient to ensure stability without doors. Especially with open designs, twisting can occur.
Additionally, many interior fittings are designed for maximum adjustability but are sometimes not sturdy enough for heavy textiles or frequent use.
Therefore, my recommendation: If you plan to use Pax for a walk-in closet, be sure to include extra reinforcements and possibly a protective facing to prevent deformation.
nidilu
8 Jul 2021 09:01
benfa schrieb:
In my experience, the back panel alone often isn’t enough to ensure stability without doors.
Thanks for the hint. How do others handle this? Are doors essential for stability, or is it sufficient to secure the cabinets to the wall?
My plan is actually to keep the cabinets open to improve visibility and access. At the same time, I want the construction to be absolutely stable.
Are there any specific stability reinforcements for the Pax units that can be added? I would appreciate any tips.
dunitan
8 Jul 2021 09:49
Wall mounting is generally highly recommended for Pax, whether with or without doors. It adds significantly more stability to the structure and prevents tipping.
We built our walk-in closet system without doors, using the sturdier frame components from the series with a depth of 75cm (30 inches). Additionally, the back panels were applied in multiple layers, and the modules were connected to each other.
If doors are used, they contribute to the stability as well but are not essential.
Tip: Plan your modules so they can be connected with partition walls, as these also provide lateral support.
angel
8 Jul 2021 10:32
In addition to stability, I would like to highlight the importance of lighting. Good lighting is essential in walk-in closets.
Ikea offers LED track lights and lighting fixtures that can be easily integrated into the Pax modules, which is especially useful when the closets are open.
This not only improves visibility but can also help to create a more open look and make the space feel brighter when combined with open closets.
Furthermore, it is better to use sturdy tracks and create space in the upper areas for seasonal clothing or items that are used less frequently.
