ᐅ Single-Family Home – Feedback on Our Design
Created on: 29 Sep 2017 23:14
MBS2201
Hello, I need your advice on how to create a better layout for the master bathroom – utility room – children’s bathroom area.
Requirements:
Children’s bedrooms are on the south side.
The children’s bedrooms should be approximately the same size. The utility room should accommodate a dryer and washing machine since we are building without a basement.
Thank you for your help.
Alex85
30 Sep 2017 07:39
It always depends on the specific implementation. However, I believe it limits your options. And “small” walk-in solutions are likely to result in puddles where none were intended. I find it hard to imagine this working in just 4 m² (43 sq ft).
11ant30 Sep 2017 13:19
Alex85 schrieb:
105 sqm (1,130 sq ft) of living space all on one level, and not a hint of spaciousness visible.
Oops, I hadn’t added it up myself — yeah, it does feel like not much more than seventy. Well, that makes me even more curious about the ground floor. It must be almost perfect if "the rest of the mess upstairs" is so tangled up. We’ve seen this before, where flaws upstairs were linked to priorities that were implemented as desired on the ground floor.
MBS2201
30 Sep 2017 23:10
Hello, thank you for the many responses. After a while, you can get overwhelmed by all the drawings.
I have (hopefully) marked a few improvements by hand and would like to ask for your opinion before having the drawing revised.
The original drawings including measurements have also been uploaded.
Regarding the stairwell: a glass front will be installed on the ground floor and only a half-height wall will be built on the upper floor. The staircase is intended to function as a room divider on the ground floor.
30 Sep 2017 23:56
Hello first of all
Designs can only be evaluated and possibly changed as a whole.
There is quite a bit missing here.
The upper floor (UF) shows that the staircase is either in the wrong position or fundamentally the wrong choice.
The room layout is not advantageous: master bedroom, child’s room 2, utility room... practically unnecessary wasted, unusable corners in the rooms. Bathroom furniture should be arranged appropriately.
No tips from me, see sentence 1!
Maybe also read my pinned post and fill out the questionnaire before you make 40 posts but still have said nothing?!
MBS2201
1 Oct 2017 00:40
Plot size: Parcel 35, 775m2 (8330 sq ft)
KFW 55 (Energy efficiency standard)
Slope: Yes
Floor area ratio (FAR): 0.35
Plot ratio / site coverage ratio: 0.80
Building envelope, building line and boundary: see site plan
Edge development: No
Number of floors: 2
Roof type: Gable roof
Style / orientation: South - Southeast
Maximum dimensions / limits: Building size Max = 14m x 10m (46ft x 33ft) + single-story extension lengthwise, Max 10m (33ft) depth, Max height 3m (10ft)
Style, roof type, building type: Gable roof
Basement, floors: No basement, 2 full floors
Number of people, ages: 4 people (3 females, 1 male), ages 40, 38, 12, 9
Space requirements on ground floor and upper floor: No basement, so space needed per floor is higher → 90m2 (970 sq ft) each
Office: Family use or home office? Planned as a home office, possibly later a bedroom / guest bedroom usage per year: 6
Open or closed layout: Open layout, at least on the ground floor attempted
Conservative or modern design: Modern design
Open kitchen, kitchen island: Open kitchen with island
Number of dining seats: 1
Fireplace: Yes, to be placed in the living room since the chimney should not run through the children’s bedrooms
Music/stereo wall: No
Balcony, roof terrace: Yes, No
Garage, carport: Double garage with partition
Additional wishes / special features / daily routine, including reasons for choices: Photovoltaic system + possible battery storage, mechanical ventilation with heat recovery, air-to-air heat exchanger, cistern
Who designed the plan: Draftsperson
- Planner from a construction company: No
- Architect: No
- Do-it-yourself: No
What do you particularly like? Why? Ground floor, due to the open design with large windows
What do you dislike? Why? Upper floor layout
Estimated price according to architect/planner: ? Personal price limit for the house, including equipment: 400,000 €
Preferred heating system: Air-to-air heat exchanger with underfloor heating
If you have to give up, which details / extensions
- Can you give up: Battery
Cannot give up:
Why is the design like it is now?
Standard design from planner? No, ideas based on show homes + floor plans from the internet
How can I improve the layout of the upper floor?
1 Oct 2017 21:46
Is the entrance on the south side?
And what about the upper floor? Has the staircase been rotated?
As I mentioned before, I don’t think this design or placement of the staircase is good, since you have to plan a hallway around it. So, I can’t really come up with a satisfactory suggestion right now.
Next time, JPGs would be better... at least some people here are willing to work with them continuously instead of using auxiliary software (like Acrobat), especially because many access the forum via mobile phones.
Mobile regards from on the go
