Dear forum members,
We bought a plot of land last autumn and are currently deep into the floor plan design. We would like to share our current draft with you and welcome any comments and opinions.
[F]irst some preliminary information about the plot and its buildability:[/F]
- 1000 m² (10,764 sq ft) rear plot, southwest facing (so southwest is on the left side of the site plan)
- Building boundary up to approx. 16 m (52 ft) behind the property line (up to the dashed line on the site plan)
- No zoning plan (construction according to § 34 of the Building Code)
- Groundwater at surface level and peaty soil (exact geotechnical report pending), so piled foundation required and no basement
- Affordable! (Our maximum budget for the house including foundation slab is €230,000)
- Country house style
- Bright, large windows facing south/garden
- Open living/dining/kitchen area
- Family of four, 1 bedroom and 2 children’s rooms
- Not oversized, max 150 m² (1,615 sq ft), preferably less
- Solid construction using Ytong blocks (for us the most cost-effective option, although we would have liked to build with wood as well).
- Developed ourselves after studying various floor plans (including from the book "Affordable Building with a Small Budget" by Achim Linhardt) with support from architect friends and our planner (an independent civil engineer).
- Dimensions 12.50 x 7.50 m (41 x 25 ft) (the measurements shown on the site plan are from an earlier draft).
- What we like: open living area, all main rooms have large windows facing the garden, efficient size, although the children’s and bedroom could be smaller, sewing/work nook behind the stairs upstairs, plenty of wall space for large wardrobes in the upstairs bedroom and hallway on the ground floor, light shaft in the stairwell, staircase (we originally wanted a straight run staircase but it would have taken too much space; the one with three quarter turns is also fine with us).
- What we don’t like 100% yet: the height of the house from the outside. It is currently planned as a two-story house with an eaves height of 6.2 m (20 ft), with the ground floor 2.84 m (9 ft 4 in) high and the upper floor 2.60 m (8 ft 6 in) high. The gable roof will be an uninsulated, unfinished cold roof, mainly because of the economical prefabricated truss construction method. This is a bit disappointing because I really like sloped ceilings and did not want the character of a townhouse. Lowering the roof with a knee wall of about 1.90 m (6 ft 3 in) and an insulated roof with open sloped ceilings would probably be more expensive due to the rafter/beam construction. We would also lose the garden view through the floor-to-ceiling bedroom windows.
- Simple: What do you think about the floor plan?
- Can you still imagine the relatively tall two-story house having a country house character? Maybe it depends on the facade design and choice of materials? Do you think it looks too “blocky,” especially from the front entrance side? Or would a lower eaves height with an attic conversion including a knee wall be preferable?
- We are still unsure how to arrange the windows on the garden side. The drawing with the elevations shows two possible versions. We actually prefer it when the upper floor window is centered over the lower window front. However, this does not align the interior line of sight from the entrance door to the garden/patio door (see ground floor plan). This represents version two; for version one, the window front would have to be shifted about one window width to the right, so that the patio door is behind the dining table. With the window front shifted left, the interior looks better to us, but from the outside it looks strange if it is offset from the upper floor window, right? What do you think?
Pinkiponk schrieb:
May I ask why? I would like to learn more.There’s nothing to learn here 😀 He probably means that the main traffic route should not be located in the living area 🙄
hanghaus20009 May 2021 09:31Pinkiponk schrieb:
May I ask why? I would like to learn more.Heat rises upwards, Anyone going to the upper floor has to pass by the living room,
No privacy.
I generally believe you can’t say "it is much more comfortable," but rather "I find it much more comfortable." It’s a matter of personal taste, just like an open versus a closed kitchen. There are strong arguments for both, and in new builds today, both styles probably occur about equally often—or at least both are seen frequently, with open kitchens perhaps even more common nowadays. Here, too, it comes down to what priorities you set: no cooking smells throughout the house versus being able to communicate while cooking.
The same applies to stairs. Privacy versus having to walk through cluttered hallways all the time. The living and dining area is generally the common space for everyone, and privacy is usually reserved for the bedrooms. I don’t see a strong need to get from the front door directly and privately to the bedroom. Our children’s friends just have to accept that they say a quick hello to us :p.
I have already mentioned several times in this thread over the past year that there are simply different opinions on certain topics, and that’s perfectly fine. By the way, for me, much less privacy would be having the bathtub in the bedroom—and you do see that occasionally 😉.
la.schnute schrieb:
Much less privacy for me would be having the bathtub in the bedroom, by the way.No way, in the reading nook with a window seat *SCNR*https://www.instagram.com/11antgmxde/
la.schnute schrieb:
Thanks, @ypg 🙂!
The kitchen window has the same sill height as the seating window and the one in the study. Another full patio door seemed unnecessary, but we wanted more light and a better view of the garden from the kitchen. It can also be used as a pass-through. Therefore, we added this window quite late and changed the kitchen layout from a U-shape to an L-shape with a small island. I would have made that a patio door – we often go out to the terrace from the kitchen to take things out (plates, food), so this way you always have to detour through the dining area. But it can of course work as a pass-through as well.
Otherwise, very nice design. The seating window will definitely be great.
kati1337 schrieb:
I think this is a really nice floor plan for your given budget. Of course, there’s always something that could be done better.
We already have a list of things we would do differently in our second house. But none of us are perfect, so why would our house be?
I’m happy for you. You will definitely enjoy your new home. Well said. And the first house will never be perfect anyway. Partly because views and requirements change over time. I would do some things differently now because other things have simply become more important to me.
