ᐅ Kitchen Photos Thread – Show Us Your Kitchens!
Created on: 16 Aug 2018 10:03
DieScholz´ens
Bought a house, estimated the renovation budget plus 10-15% for inevitable extras, and we set aside 5000 EUR for the kitchen!!!!
That’s how it started... at first, I was in a bit of shock, but we still had time. First step: remove all the walls for a new layout—I need space...
Let’s start with the (according to the agent) move-in ready property. The small kitchen, just under 8 square meters (about 86 square feet), had its 1970s pass-through removed. The wall including the kitchen door is gone! The wall next to the cellar stairs is gone too! Actually, the entire slanted wall, nearly 7 meters (23 feet) high, removed completely...
The window had to go as well since we needed a different working height than the standard 90 cm (35 inches). New screed installed, we switched to underfloor heating, all electrical wiring and water pipes are new.
After almost six months, the realization slowly sank in: the kitchen budget will not exceed 5000 EUR, so we had to look for a used kitchen... something special, but very cheap.
The search criteria: within a 100 km (62 miles) radius, up to 1000 EUR, because I still want new appliances.
Open living area with modern white kitchen, bright flooring and lots of light
Kitchen area with red tiled backsplash, white base cabinets and window
Bright, empty living room with white walls, laminate flooring and built-in shelf.
Bathroom under construction with floor tiles, red wall tile and sanitary connections
Kitchen shell with tiled floor, building materials and open ceiling during renovation
Construction site inside house with bare walls, cables and construction waste.
Child in winter jacket looking at unfinished interior with exposed walls and construction work.
Two workers renovating interior; exposed walls, tools and cable reels visible.
Interior finishing and remodeling: construction work in renovated space with open installations.
shenja
2 Dec 2020 17:19
I know that. I was just not sure if the front panels are the same.
halmi
2 Dec 2020 17:32
According to the catalogs, the different Lava variants are available in both series and should be identical or come from the same production line.
If you like, for example, Lava silk matte or glass matte finishes, I would consider whether the standard modular dimensions would also work for you, as this can save a significant amount of money.
O
Obermuh
2 Dec 2020 17:53
shenja schrieb:
If Lava from Next125 is similar to Lava from Schüller, then everything is visible. But it depends on the lighting. For us, everything is visible.
Do you have Lava in high gloss or matte? We chose matte because it clearly shows fewer fingerprints than the glossy version.
shenja
2 Dec 2020 20:35
We have a matte front.
There are also pictures of our kitchen in this thread.
daniel1985ffo
18 Mar 2021 09:32
Yesterday our kitchen was delivered and installed.
Unfortunately, the Siemens dishwasher could not be delivered on time due to the change in energy labels.
The kitchen is from Meda Küchen in Berlin, from the Häcker Classic Laser Soft series.
The fronts are aquamarine, and the cabinet bodies, countertop, and backsplash are in graphite.
We really like it.
We also got a matching Danish street lamp that perfectly matches the color.
Modern kitchen with black countertops, green base cabinets, and sink under the window.
Modern kitchen with green fronts, oven, extractor hood, and long handles
Modern kitchen with green fronts, black countertop, oven, extractor hood, and sink by the window.
kati133718 Mar 2021 10:31
Very, very stylish! I really like the choice of colors, and the kitchen is nicely designed as well. Simple and elegant.
Will there be a table placed under the lamp, or what are your plans for that area?
