ᐅ How can I integrate Ikea Metod cabinets into an open-plan kitchen?
Created on: 7 Aug 2021 14:23
Padarryl
Hello everyone, I am currently planning my new open kitchen and want to incorporate IKEA Metod cabinets, but I have some uncertainties about how to integrate them as harmoniously as possible into an open layout. My main question is how to best incorporate Metod kitchen cabinets into an open-plan kitchen-living area without making the kitchen too dominant or losing the sense of openness in the space. It is also important for me to know which finishes, colors, and arrangements work best to create a harmonious overall look, and if there are any practical tips for installation that I should definitely consider during planning. Perhaps someone here has experience with this or ideas on how to make the Metod cabinets appear visually lighter so they don’t feel bulky or intrusive in the room. Thank you in advance for your advice!
Keatondra
8 Aug 2021 11:49
Hello Padarryl, regarding your questions:
Indirect LED lighting under base cabinets works well if you choose narrow LED strips that are not directly visible. Mount them at the back, along the lower edge of the plinth to create a floating effect. The warm white light looks very subtle and cozy.
I also used glass backsplashes in my open kitchen; they are easy to maintain and reflect light slightly, making rooms appear larger. Just make sure it is frosted or clear lacquered safety glass to create a high-quality impression.
The transition to the living room wall unit is successful using the same or similar materials for the fronts or with a consistent color scheme. For example, I combined my white Metod fronts with open wooden shelves that extend into the living room.
This creates a connection without a harsh separation.
Tatovin
8 Aug 2021 13:06
LED strip lights at the base are ideal for subtle accents. Glass backsplashes are excellent in open kitchens due to their reflective qualities and ease of maintenance. It is best to design the transitions between the kitchen and living area using the same materials.
Z
zartra
8 Aug 2021 14:20
Just a quick note: For a lighter feel, open shelves or half-height cabinets work well with Metod. This keeps the view open and prevents the kitchen from feeling like a box in the room. For a more modern look, try handleless fronts combined with suitable LED lighting – this highlights the furniture without making it look bulky.
JAMESONB41
9 Aug 2021 10:11
Linavin schrieb:
The Metod cabinets are standardized and can therefore appear quite bulky.
It is better to consider the living space and possibly reduce the furniture height. Glass doors or open shelves help to lighten the overall look.
Liduta
9 Aug 2021 12:33
One more tip for planning: If you are using a light-colored glass backsplash, don’t forget the wall behind it. A neatly plastered or painted wall without stains ensures a perfect overall appearance.
For transitions between Metod units and the living area, custom-made sideboards based on Metod are a solution that provides both storage and a visual connection. You can experiment with recessed handles and low heights.
Also, plan your lighting very carefully – different zones (work area, dining space, living area) benefit from varying levels of brightness and color temperature.
blapau
10 Aug 2021 09:17
Padarryl schrieb:
Finally, I’m interested to know if anyone has designed the transition from Metod to the adjacent wall unit, so that the kitchen flows seamlessly into the living area.
In my experience, this works well when you use the same color tones and material combinations in both areas. For example, tall kitchen cabinets that continue the color scheme into a lowboard in the living room.
Another option is a subtle step back, such as setting the kitchen slightly recessed or visually separating it with a change in flooring. This maintains the open-plan feel while still defining distinct zones.
