ᐅ Keyless Entry Systems
Created on: 22 Aug 2016 12:38
readytorumble
I am currently considering the access system for our new build. I am thinking of a keyless system with PIN entry, fingerprint sensor, or something similar.
Which manufacturers should I look into more closely? What systems are you using?
The system is for access to the front door and the garage door. I would prefer not to carry a key, chip, or anything like that.
Security and burglary protection are, of course, very important. The sectional garage door must be able to be opened and closed remotely by radio from the car.
Thanks and best regards
RobsonMKK23 Aug 2016 17:59
Sebastian79 schrieb:
Or simply no lock on the front door
And what about power outages if there is no side or back entrance?
Sebastian79
23 Aug 2016 18:01
Then you either get unlucky and have to wait, or you simply have a side entrance – we have one, so it’s never been an issue for us.
But the power outage is another matter... when was the last time there was one, especially combined with being away from home?
Payday
23 Aug 2016 18:08
Well, any door needs a lock with a key. If the front door doesn’t have one for security reasons, then the side door will just be opened instead...
There is also a solution with an integrated electronic lock system, where the door is opened by battery power. Power outage doesn’t matter, but the system failing is the risk. So it’s better to still be able to open it with a key somehow. We’ve already had this happen 2-3 times when the door wouldn’t open. The most likely reason was that the door was not properly closed.
Burglars don’t usually break in through the expensive front doors with all the flashy features visible from the outside, but rather through the well-hidden patio door with privacy screening...
RobsonMKK23 Aug 2016 18:14
But the power outage issue is also something... when was the last time we had one, and especially combined with being away from home?
It hasn’t been even two years for me, so it can definitely happen.
I would also like to have a system like that, but my wife is very skeptical. Also because acquaintances have such systems and frequently struggle with outages.
Sebastian79
23 Aug 2016 18:16
Exactly, that’s why I didn’t spoil my nice door from the outside with a profile cylinder.
We have no outages or other problems—just two side entrance doors where keys are kept.
Mycraft23 Aug 2016 18:26
I have had an Anykey from Ikon here for years... it is used quite often in offices and is relatively secure... basically as secure as a coded lock usually is.
