I am currently considering the access system for our new build. I am thinking of a keyless system with PIN entry, fingerprint sensor, or something similar.
Which manufacturers should I look into more closely? What systems are you using?
The system is for access to the front door and the garage door. I would prefer not to carry a key, chip, or anything like that.
Security and burglary protection are, of course, very important. The sectional garage door must be able to be opened and closed remotely by radio from the car.
Thanks and best regards
Sebastian79 schrieb:
However, everything runs through their servers – so it's neither secure in terms of connection nor in the future if the servers are ever shut down. I also looked into the BJ, but couldn’t find any indication that it operates via their servers. Without the IP Gateway, it doesn’t even have a network connection. Are you sure about that?
Sebastian7922 Aug 2016 21:52I was referring to the version with the IP gateway – without it, it’s just a basic audio/video intercom system.
Well, basic but with an abnormal additional cost.
I was referring to the version with the IP gateway – without it, it's just a standard audio-video intercom system.If I understand correctly, the IP gateway is mainly for using the mobile apps and is optional. But then, what else can you do with the gateway besides connecting the panel, if you don’t use the apps?R
readytorumble23 Aug 2016 07:15eKey sounds the most interesting to me so far.
Server-based or similar solutions are absolutely not an option.
I am also interested in a keyless system, mainly for situations when someone forgets their key. There are only two of us living here, and we are both often away on business trips. At the moment, we haven’t left a key with the neighbors, so it would be quite problematic to find ourselves locked out. I don’t want a high-tech solution (even though that might be tempting), but the ability to quickly add or remove fingerprints is important. It should also be possible to enable fingerprints only temporarily (for visitors, cleaning staff, etc.).
Sebastian7923 Aug 2016 08:20@86bibo:
EKey, although temporary activation is only possible with the more expensive network version.
