ᐅ Keyless Entry Systems
Created on: 22 Aug 2016 12:38
readytorumble
I am currently considering the access system for our new build. I am thinking of a keyless system with PIN entry, fingerprint sensor, or something similar.
Which manufacturers should I look into more closely? What systems are you using?
The system is for access to the front door and the garage door. I would prefer not to carry a key, chip, or anything like that.
Security and burglary protection are, of course, very important. The sectional garage door must be able to be opened and closed remotely by radio from the car.
Thanks and best regards
Stefan890
27 Oct 2018 14:05
Mycraft schrieb:
Doorbell button, relay module, door buzzer, IP camera – nothing more is needed for a basic setup.
Can someone recommend a simple video intercom system (with a/b interface for the FritzBox)?
Uwe8228 Oct 2018 07:29
If you can assemble everything yourself and have the time for it, it is usually cheaper. But is that really an argument? After all, you have to factor in the time required. It’s the same when installing and configuring KNX yourself. I did that too, but sometimes you have to draw the line with all the tinkering.
And as I said: this system can do a lot more, which would require a server or Raspberry Pi again if you use an IP camera. And then the time factor comes into play once more.
