ᐅ KALLAX Doors and Magnets – Which Are Compatible?
Created on: 30 Oct 2022 09:13
Iriskau66
I am planning to equip my IKEA KALLAX shelving unit with doors and have a specific question regarding the compatibility of magnetic catches. Many sources online recommend magnetic catches or so-called “magnet clips” for the doors. However, it is unclear which magnets or locking mechanisms are actually compatible with the KALLAX doors, especially regarding strength, size, and mounting.
Therefore, I would like to know:
Which magnetic catches or magnet types are reliable and compatible with IKEA KALLAX doors? Are there any experiences regarding installation (e.g., screwing or gluing), durability, and stability?
It would also be important for me to know if there are any specific IKEA magnetic solutions or recommendations for third-party products that have proven to work well. I look forward to your detailed feedback as I am seeking a long-lasting and neat solution.
roryvin
31 Oct 2022 10:42
Regarding your questions:
1. Good screw-on magnets often come from brands like 'Bachmann' or simple generic neodymium magnets with brass or steel threads. The pulling force should be around 1.5 kg (3.3 lbs).
2. Most models are two-part: one part is screwed onto the door, and the counterpart is a thin magnetic plate, which is attached with an offset of 1–2 mm (0.04–0.08 inches) to ensure proper grip. Unfortunately, small adjustments are needed for precise alignment.
3. For gap clearances, place the magnets centered on the side edge of the door and use two per side depending on the door size. At the bottom, they should be positioned no more than 2–3 cm (0.8–1.2 inches) away from the door frame. This ensures clean closing without warping.
Espen
1 Nov 2022 08:09
It also helped me to use washers when the magnetic plate does not sit flush against the wood. This way, the door remains stable and the magnetic contact fits properly.
gojan7
1 Nov 2022 08:40
Positioned on the left and right, with 2 pairs of magnets each, is completely sufficient for me on 4 doors. It has held perfectly after 3 months.
boelnu
1 Nov 2022 09:51
I appreciate how details like pilot holes and gap tolerances are being discussed here. It shows that even seemingly simple projects require a lot of care. 🙂
For me, the most important takeaway is that screw fastening truly forms the backbone of a long-term solution.
Thank you all for the tips!
Hector
1 Nov 2022 10:33
Finally, I would like to point out that when selecting magnets, in addition to pull force and installation, one should consider possible effects from environmental factors such as humidity. MDF especially absorbs moisture, which can potentially affect the fit in the long term.
Therefore, after installation, the shelf should be kept as dry and temperature-controlled as possible to prevent warping.
