ᐅ KALLAX Doors and Magnets – Which Are Compatible?
Created on: 30 Oct 2022 09:13
Iriskau66
I am planning to equip my IKEA KALLAX shelving unit with doors and have a specific question regarding the compatibility of magnetic catches. Many sources online recommend magnetic catches or so-called “magnet clips” for the doors. However, it is unclear which magnets or locking mechanisms are actually compatible with the KALLAX doors, especially regarding strength, size, and mounting.
Therefore, I would like to know:
Which magnetic catches or magnet types are reliable and compatible with IKEA KALLAX doors? Are there any experiences regarding installation (e.g., screwing or gluing), durability, and stability?
It would also be important for me to know if there are any specific IKEA magnetic solutions or recommendations for third-party products that have proven to work well. I look forward to your detailed feedback as I am seeking a long-lasting and neat solution.
gojan7
30 Oct 2022 14:17
KALLAX doors: Use neodymium disc magnets with screw mounting, about 10 mm (0.4 inches) in diameter, 2 pieces per door. Holds securely, nothing slips.
boelnu
30 Oct 2022 15:06
At the beginning, I had problems because I used weak adhesive magnets – the doors kept opening slightly. It was frustrating, as the effort is supposed to be minimized. Since then, I have been using screw-in magnets and am really satisfied. It was also important for me that the solution looks good and does not appear bulky.
Hector
30 Oct 2022 16:24
It is interesting that screws are often mentioned. However, we should consider whether they might affect the surface or the structural integrity of the KALLAX door.
boelnu schrieb:
since then I have been using screw magnets and am really satisfied.
Are screw magnets truly problem-free, especially regarding potential cracks or deformations? I would also like to know how magnetic holders perform under continuous stress compared to adhesive magnets. Are there reliable experiences available?
KARJU
30 Oct 2022 17:48
Regarding load-bearing capacity and material damage:
Screw magnets cause minimal effort, provided a well-pre-drilled position is chosen. The KALLAX doors are not solid, but with the correct screw size (small Phillips screws, 10-12 mm (0.4-0.5 inches) in length), the material loss is negligible.
On the other hand, adhesive magnets are often unstable due to the smooth surface and temperature changes, leading to a loss of adhesive strength. Therefore, screw magnets are the recommended solution for long-term stability.
O
olivernu
30 Oct 2022 18:17
In addition to Hector and KARJU: It is advisable to pre-drill pilot holes with a thin drill bit for the screw magnets to prevent splitting the MDF. You can also place small felt or plastic washers under the screw heads to further protect the wood.
Regarding the structure of the KALLAX doors, the material is thin but generally sturdy enough for such fittings if handled carefully.
Iriskau66
31 Oct 2022 09:15
Thank you for the very helpful responses so far!
To summarize, I have understood:
– Screw-in magnets with neodymium work very well, are sturdy, and require pre-drilling
– Adhesive magnets are generally less reliable
– There are no specific IKEA KALLAX magnets, but IKEA magnetic hinges for smaller cabinets are an option
I would still like to know:
1. Are there any particular brands or model names for these screw-in magnets?
2. What exactly do the fittings for screw-in magnets look like (e.g., with a counterplate? Direct screwing?), to prevent the door from warping?
3. Can you provide recommendations on the best positions or distance from the door frame? Especially whether the magnet arrangement affects the lifespan of the doors or if it really helps achieve minimal gap tolerances.
I am currently planning the drilling and want to be as well prepared as possible.
