ᐅ KALLAX Doors and Magnets – Which Are Compatible?
Created on: 30 Oct 2022 09:13
Iriskau66
Iriskau66
30 Oct 2022 09:13
I am planning to equip my IKEA KALLAX shelving unit with doors and have a specific question regarding the compatibility of magnetic catches. Many sources online recommend magnetic catches or so-called “magnet clips” for the doors. However, it is unclear which magnets or locking mechanisms are actually compatible with the KALLAX doors, especially regarding strength, size, and mounting.
Therefore, I would like to know:
Which magnetic catches or magnet types are reliable and compatible with IKEA KALLAX doors? Are there any experiences regarding installation (e.g., screwing or gluing), durability, and stability?
It would also be important for me to know if there are any specific IKEA magnetic solutions or recommendations for third-party products that have proven to work well. I look forward to your detailed feedback as I am seeking a long-lasting and neat solution.
Espen
30 Oct 2022 09:46
I used standard round neodymium magnets myself, about 12mm (0.5 inches) in diameter, simply fixed with screws. They hold well and do not slip. Gluing is not as durable on the KALLAX doors.
notupra
30 Oct 2022 10:02
I used an IKEA magnetic set that is originally designed for cabinet doors. It fits perfectly since it is made for wooden doors. Installation is simple, using small screws.
O
olivernu
30 Oct 2022 11:25
The use of magnetic catches on KALLAX doors depends greatly on the material thickness. The doors are relatively thin, so strong magnets are needed to ensure a secure hold over time.
I recommend magnetic hinges or magnetic catches with at least 1.5 kg (3.3 lbs) holding force. Magnets that are too weak can cause warping and poor sealing in the long run.
For fastening, small screws are the better option, as adhesive does not bond well with the surface of the door material.
There are also retrofit magnetic sets available at IKEA designed specifically for this purpose – especially the "EKERÖ" or "STÖDIS" magnetic catches they offer for smaller cabinets.
KARJU
30 Oct 2022 12:34
For systematic classification:
- Material and door thickness: KALLAX doors are made of thin MDF or veneered particleboard, approximately 10-12 mm (0.4-0.5 inches).
- Magnetic force: At least 1.2 to 1.5 kg (2.6 to 3.3 lbs) of holding force.
- Fastening: Screws are mechanically more durable than adhesive pads, as the paint finish often does not provide optimal adhesion.
Regarding compatibility, there are no IKEA standards for magnets specifically for KALLAX, so universal magnets from third-party suppliers are usually the first choice.
My tip: Magnetic systems that allow for easy adjustable installation (slidable plates or small hinges with magnets) to compensate for gaps.
roryvin
30 Oct 2022 13:55
The door size and surface texture of the KALLAX series make it somewhat challenging, as the magnets need to be not only strong but also precisely installed to ensure a proper closing.
I have had good experiences with magnetic catches from hardware stores, which are specifically designed for cabinet doors. It is important to correctly position the counterpart magnets or metal plates to achieve a secure closure.
Additionally, I recommend marking the exact position with a marker before attaching, to avoid damaging the doors.
