ᐅ Is it possible to replace Pax units with sliding doors by yourself?
Created on: 14 Apr 2020 08:21
Tarkin7
Tarkin7
14 Apr 2020 08:21
Hello everyone, I’m currently working on modifying my Pax wardrobe and was wondering if it’s possible to replace the existing sliding doors myself without fully dismantling the frame or hiring a professional.
I have already looked at some IKEA instructions, but they mostly cover the initial assembly. My sliding doors still work well technically, but the design no longer matches my interior.
My specific question is: Is it possible, and to what extent, to replace the sliding doors of a Pax wardrobe on your own? What tools are required, and are there any particular points to watch out for in order to avoid damaging the frame or the sliding tracks?
I would really appreciate practical tips, personal experiences, and possibly advice on the different sliding door options.
Grace
14 Apr 2020 09:45
Hello Tarkin7,
I’m happy to help you with this. Basically, it is definitely possible to replace the sliding doors of a Pax wardrobe yourself without dismantling the entire frame.
It’s important to be careful with the sliding rails when removing the old doors, as they are fragile. The tools you usually need are a screwdriver (Phillips or flathead, depending on the screws) and possibly a rubber mallet if the doors are a bit stuck.
When installing new sliding doors, you should align them precisely and make sure the rollers sit cleanly in the guide rails so that they run smoothly later on.
If your Pax system has sliding doors with an upper rail system, you can often simply unhook the doors and hook the new ones in without much extra work. There are different variants, including glass or wooden doors, which may be installed in different ways.
If you say your doors are still technically fine, I assume you don’t need to modify the sliding rails—just carefully unhooking and rehanging the doors.
If you could describe more precisely what kind of sliding doors you have (material, dimensions, upper rail or center track rails), I can give you more targeted advice.
reni45
14 Apr 2020 10:11
Yes, it is possible to replace the sliding doors of Pax yourself. It is important not to bend the tracks and to handle the doors carefully. Tools usually required are just a screwdriver and possibly an Allen key.
Palenar
14 Apr 2020 11:37
Hello Tarkin7,
a detailed answer to your question requires a bit more technical information, as Pax sliding doors use different systems, which largely influence the approach.
Basically: Replacing sliding doors on Pax wardrobes is possible, but you should follow certain steps carefully to avoid damage.
1. Preparation:
- Remove all shelves if possible to reduce weight.
- Check the tracks for damage or dirt that could make removing the doors difficult.
2. Removing the doors:
- With common top track systems, you can loosen the upper guide or carefully lift the doors and take them out of the track.
- Be careful when detaching the lower roller wheels – sometimes they are firmly locked into the track.
3. Tools:
- Screwdrivers (Phillips and flathead)
- A small Allen key for adjusting the roller screws
- Rubber mallet for gentle assistance
4. Tips:
- Work with two people; the doors can be heavy and awkward to handle.
- Document the positions of screws and track components with photos to make reassembly easier.
- Make sure the new doors exactly match the measurements to avoid complications with spacers or tracks.
I am wondering if your Pax system uses only two sliding doors or more, as that can make the replacement simpler or more difficult. Could you clarify this?
Overall, it makes sense to plan carefully and consult Ikea’s assembly instructions – even though that requires more effort.
refinar
14 Apr 2020 12:53
I would like to add a brief guide on how to safely replace Pax sliding doors:
1. Safety first: Always wear gloves, as the edges of the doors made of glass or metal can be sharp.
2. Preparation:
- Clear the area to prevent damage to the doors during removal and installation.
- Gather your tools: screwdriver, rubber mallet, possibly a cordless drill with the appropriate bit.
3. Removing the doors:
- Expose the top track: loosen screws or remove covers.
- Lift the doors slightly to take the bottom rollers out of the track.
4. Inspect the tracks:
- Clean the guide rails thoroughly.
- Check the rollers for damage; faulty rollers can make the replacement more difficult.
5. Installing the new doors:
- Adjust the rollers on the new doors precisely.
- Insert the doors into the bottom track, then hang them into the top track.
- Then check whether the doors slide smoothly and evenly.
6. Finishing touches:
- If the doors don’t glide smoothly, readjust as needed.
- Reattach the track covers.
7. Special considerations:
- Pay attention if your new doors come with additional dampers or special locks.
- Note the weight limits of the sliding door systems.
Summary: Yes, replacement is possible, but technical knowledge and a careful touch are required. Mistakes in adjustment or handling can lead to permanent damage.
If you’d like, I can also provide a short checklist for download.
Tarkin7
15 Apr 2020 07:34
Palenar schrieb:
I’m still wondering if your Pax uses only two sliding doors or more; that makes replacement easier or more complicated. Can you clarify?
Thank you very much for the detailed explanations! My Pax actually has three sliding doors, with dimensions of approximately 236 cm (93 inches) in height and 201 cm (79 inches) in width. It is the top-rail system, meaning the track runs along the top and there are rollers at the bottom.
So far, I haven’t noticed any serious damage, but I do find that the right door is a bit harder to slide. Therefore, I plan to replace the entire system – including the doors.
I’m fairly handy, but I’m worried that the doors are so large and heavy that I might quickly reach my limits. Are there any tips on how to safely uninstall and handle the doors without needing someone to help?
