ᐅ Which tools are essential for assembling the Ikea Pax wardrobe?
Created on: 30 Sep 2022 10:17
Peppa5
Peppa5
30 Sep 2022 10:17
Hello everyone, I’m currently planning to assemble the Ikea Pax wardrobe and want to prepare well in advance. My question is for those who have experience with the assembly: Which tools are absolutely necessary to complete the Pax setup efficiently and without unnecessary back-and-forth? I’m not only referring to the standard tools, such as the Allen key that Ikea provides, but also any additional tools that can really help, for example to fasten screws more easily or quickly, or to better align parts. I’d appreciate specific recommendations and maybe some tips on what to watch out for to avoid complicating the assembly.
Emery
30 Sep 2022 10:46
Basically, the included Allen key is sufficient for many screws, but using a power screwdriver with the appropriate bit makes assembly much easier and saves time. Additionally, a rubber mallet can help to gently fit parts together without damaging the materials. It’s also useful to have a spirit level on hand to ensure the cabinet is properly aligned. For precise work, it’s a good idea to have a longer screwdriver available to reach screws in tight spots.
emmett
30 Sep 2022 11:03
Allen keys, cordless screwdrivers, spirit levels, and rubber mallets are the most essential tools; you don’t need anything more.
SauDietmar
30 Sep 2022 12:25
Let me explain this in a bit more detail, as assembling the Pax system involves a few small tricks where having the right tools really makes a difference:
- Allen key: Of course, this is essential, but the IKEA-provided key is often too short and awkward to use. It’s better to invest in one with a shaft, which makes screwing much easier.
- Cordless drill/driver: An indispensable tool, especially when dealing with many screws. It’s important to use one with adjustable torque to avoid over-tightening screws or damaging wood surfaces.
- Rubber mallet: Ideal for tapping in profile rods or back panels without causing damage.
- Spirit level: Needed not only for leveling the cabinet base but especially when mounting the cabinets on the wall.
- Possibly a small screwdriver or a cross-head bit, in case some fittings require it.
Tip: Preparation is everything. Sort the screws according to the contents list beforehand to minimize searching during assembly!
PeoDaniel
30 Sep 2022 13:41
I would like to add that the importance of a stable work surface is often underestimated. Although the Pax wardrobe is large, many parts are quite delicate, especially the doors. So, when working on carpeted floors or uneven surfaces, using a large, smooth cardboard sheet or a blanket is helpful to prevent scratches.
Also, regarding screws, a torque wrench is not absolutely necessary, but it is important to tighten them very carefully to avoid damaging the particleboard. As for tools, a small hammer (not steel, but wood or rubber) is also useful for gently tapping in dowels.
Nofege
30 Sep 2022 15:09
To add to the previous suggestions:
- A longer Allen key or a hex bit holder that fits into the cordless drill is worth its weight in gold
- Fine sandpaper can help with precise alignment if something doesn’t fit quite right
- When tightening screws, I recommend starting with a light tightening and only fully tightening at the end. This prevents warping or breaking parts
- A small tip: A screwdriver with a magnetic tip holds screws much better during insertion and makes assembly significantly easier
Common mistakes I’ve often seen include overtightening the fittings and neglecting alignment, especially when installing multiple Pax wardrobes side by side.
