ᐅ Installing a Miele dishwasher and oven in an IKEA Metod kitchen?
Created on: 23 Feb 2016 13:13
Brummsummsal
Brummsummsal23 Feb 2016 13:13
I would now like to gradually say goodbye to my 30-year-old kitchen and retire it.
However, I would like to keep the electrical appliances, as they are only a few years old.
The stove is still working fine, but the dishwasher is the issue.
It is a Miele unit with a height of 65 cm (26 inches). How can I fit it into an 80 cm (31.5 inches) cabinet so it still looks good?
The appliance has a visible control panel on the front.
Here comes the next problem: the front panel. The current one is 60 cm (24 inches) wide and 57 cm (22.5 inches) high.
If I use an IKEA front panel measuring 60 x 60 cm (24 x 24 inches) ........?
Do the mounting brackets or rails from IKEA fit every dishwasher?
The next problem is the stove.
The cabinet is not the issue, but..........
the stove should be installed diagonally in a corner because I have a brick chimney with an integrated extractor hood that I don’t want to part with.
Setting the stove with the cabinet at the right angle is clear, but what about the countertop around it?
No matter how I rotate or adjust it, it’s not deep enough.
Can I piece together the rear part?
What should I use to connect it?
The IKEA rails offered are not exactly attractive, especially when they run crisscross like that.
Do you have any tips for me?
Thanks in advance,
Anita
Brummsummsal
IKEA-Experte
23 Feb 2016 14:57
the dishwasher usually is not installed inside a cabinet and is not 65 cm (26 inches) high. Which model is it?
Semi-integrated dishwashers are installed with ERSÄTTARE.
For the countertop, you need a custom-made Personlig countertop. The grooves for joining the pieces are also made during this process.
Brummsummsal23 Feb 2016 18:33
Yes, I have already found out that the dishwasher is freestanding, meaning it stands on its own feet.
(Those who can read clearly have an advantage.)
Only the baseboard is then pushed in front of it.
It is a Miele G 1022 SCI.
It’s good that the countertop situation is already sorted out.
Anita
IKEA-Experte
23 Feb 2016 19:04
The dishwasher should be installable with ERSÄTTARE. According to the specifications, the feet cannot be unscrewed enough. You can buy taller feet from Miele or place the machine on a thick board.
