I would like to install plastic floor glides under the Pax wardrobes, as I need to move one of the wardrobes once a year (underfloor heating).
Does anyone have experience with this?
Regards,
hamburgerjung_5582
Regards,
hamburgerjung_5582
hamburgerjung_558215 Nov 2015 14:03That’s a great idea, but can this roller (especially on the particle board of the Pax wardrobe) support a fully loaded wardrobe?
IKEA-Experte15 Nov 2015 17:32One roll weighs 40 kg (88 lbs), 12 rolls weigh 480 kg (1,058 lbs). The rolls should be able to handle it, but you’re probably more concerned about the connection to the side panels. Using butt Euro screws would be beneficial. Maybe there are also rolls with a different type of fastener. Or you could slide something under the side panels once the cabinet is back against the wall. Hmm, but that would stick out so you could pull it out again. So, not such a great idea.
hamburgerjung_558216 Nov 2015 11:24One roller supports 40 kg (88 lbs), so 12 rollers support 480 kg (1,058 lbs). The rollers should be strong enough, but you’re probably more concerned about the connection to the side panels. Using flush Euro screws would be advantageous. Maybe there are rollers with a different type of fastening available. Or once the wardrobe is back against the wall, you could slide something underneath the side panels. Hmm, but that would stick out to make it possible to pull it back out again. So, not a great idea.Not really... Does anyone have a “bottom view” of a Pax wardrobe? Then I can take it to my trusted carpenter, maybe they’ll have an idea...
