ᐅ How to Properly Clean IKEA Metod Countertops and Prevent Scratches
Created on: 25 Jul 2022 08:34
Ertanma
Ertanma
25 Jul 2022 08:34
Hello everyone, I recently installed an IKEA kitchen with METOD cabinets, including countertops, and I want to clean them properly without causing any damage. My main questions are: Which cleaning agents are best suited for METOD countertops (or the common surfaces like wood effect, laminate, or stone effect) to effectively remove dirt and stains? And how can I avoid scratches or dull spots that might result from incorrect cleaning or overly harsh products? Are there any specific care instructions from IKEA or practical experiences you can share to help maintain the durability and appearance of the countertops over time? I would appreciate targeted tips and practical advice, including any differences depending on the countertop material.
edisondan
25 Jul 2022 09:12
The following can be said about IKEA’s METOD countertops: IKEA generally recommends using mild, neutral cleaning agents for laminate or wood-look surfaces that do not contain abrasives or alcohol. Ideally, pH-neutral all-purpose cleaners or a damp cloth with a little dish soap are best for removing grease. Harsh cleaners, abrasive pads, or rough sponges should be avoided, as they can permanently damage the surface. Scratches mostly occur through mechanical stress, such as from knives or coarse objects. Therefore, it is advisable to use cutting boards and avoid cutting directly on the countertop. Additionally, liquids like oil or strongly staining substances should be wiped off promptly to prevent discoloration. The countertops are relatively easy to maintain, but regular gentle cleaning helps preserve their appearance and protective layer over time. Similar guidelines apply to stone-look or quartz surfaces, although these tend to be more resistant to scratches.
GiRoyce
25 Jul 2022 14:47
I can fully confirm edisondan’s advice. One more tip: absolutely avoid contact with sharp or metal objects directly on the countertop. For stubborn stains, warm water with mild dish soap and a soft microfiber cloth work best. Afterwards, wipe the surface dry to prevent water spots and limescale marks. Important: do not use abrasive cleaners or steel wool – these damage the surface significantly. If you have a wood-look finish, a special wood care product can also help, but use it sparingly.
PAREL
26 Jul 2022 10:23
To complement this, here is a brief cleaning tutorial that clearly outlines the proper steps for METOD countertops:
- Preparation: First, roughly remove dust or crumbs from the countertop using a dry cloth.
- Cleaning: Dampen a microfiber cloth with lukewarm water and a few drops of pH-neutral dishwashing liquid. Clean gently using circular motions.
- Stain treatment: For tougher stains, let the solution sit for a little longer, but do not rub.
- Rinsing: Wipe the surface with a clean, damp cloth without any cleaning agents.
- Drying: Thoroughly dry with a dry cloth to prevent water spots.
- Protection: For wood or wood-effect countertops, it is recommended to occasionally apply a suitable care oil (refer to the IKEA instructions if needed).
[Attention:] Never use abrasive cleaners or alcohol-based products, and avoid rough sponges or steel wool.
Unfortunately, prevention is usually the only solution for scratches, not repair. Use cutting boards and coasters. A smooth countertop design like METOD greatly benefits from careful handling.
