ᐅ Creating a comfortable bathroom environment
Created on: 3 Aug 2016 09:16
RobsonMKK
I need some help.
Yvonne suggested I start a separate thread so I might get more input for my planned bathroom.
You’ll find a screenshot attached; here are some details about the dimensions:
- The room measures 3.95 x 3.21 meters (at the door there is a recess 20 cm (8 inches) deep)
- The knee wall height is over 1 meter (3 feet) above the finished floor level, the 2-meter (6 feet 7 inches) line is at about 80 cm (31 inches) (as marked)
- The shower should be 1 x 1 meter (3 feet 3 inches x 3 feet 3 inches)
- The bathtub is currently a “standard” size at 1.75 meters (5 feet 9 inches) long and 75 cm (30 inches) wide
I don’t want to add more ceramic fixtures than what is shown.
I had also considered a hexagonal tub, but that wouldn’t really help much either.
Thanks in advance for your help
Robin
Draufsicht eines Badezimmers mit Toilette, Badewanne und Waschbecken auf grauen Fliesen
tomtom795 Sep 2016 20:12
I would extend the bathtub all the way to the wall by the toilet!
Or what do you plan to put in the recess?
And how is the door supposed to operate?
RobsonMKK5 Sep 2016 20:17
Forgotten, the niche needs to be sealed. And the door recess is the wrong way around, but the software is currently acting up.
kbt09
5 Sep 2016 20:38
Isn’t the sloping roof on the left side? I wouldn’t change the door’s hinge side there. The door should just be moved further to the left. You will probably need a floor stop for the door, and it can be better positioned in the corner near the bathtub than in front of the washbasin.
How large is the shower niche here? It looks a bit narrow. Also, if it is intended to be doorless, the wall beside the washbasin should be at least 160 cm (63 inches) wide. Is it?
Jochen1045 Sep 2016 20:49
@kbt09, the door is at the top right on the plan. The window is centered in the layout 😉
RobsonMKK5 Sep 2016 21:00
The shower is 100 cm (40 inches), and the washbasin wall is currently planned at 160 cm (63 inches).
And Jochen is right about the door; it’s a bit hard to see.
@Jochen104 thanks again for the original idea
5 Sep 2016 23:21
Position the bathtub between platforms of equal height to serve as a shelf, and omit the unnecessary privacy panel.
The toilet needs to be moved forward by about half a meter (20 inches) to reach the 2-meter (79 inches) height.
