ᐅ How can you check for issues with Malm furniture before purchasing?
Created on: 10 Dec 2020 08:37
Fapaolo3
Hello everyone, I am currently planning to buy an IKEA Malm desk but have often heard about issues with stability, workmanship, and the furniture panels. My question is: How can I specifically check when purchasing if my Malm piece is affected by common problems such as uneven finishing, crooked edges, boards that appear damaged or worn, or unstable connections? What should I pay attention to during an on-site inspection to avoid unpleasant surprises at home and unnecessary returns? Are there specific tests, practical tips, or visible indicators that should not be overlooked? Thanks for your advice!
Fapaolo3
10 Dec 2020 11:04
Thank you for the previous tips! Checking the drawer movement and the stability of the joints already sounds very helpful. Could you perhaps explain in more detail how to test the stability without damaging the piece of furniture? And what about the surfaces – is just looking enough, or are there specific spots you should feel for? Are there any experiences with certain batches or furniture stores where the quality is better or worse?
Torsten45
10 Dec 2020 11:29
When checking stability, gently shake the piece of furniture in different directions with moderate force, avoiding excessive pressure. This helps identify loose joints or unstable constructions. The corners of the carcass and the connection points to support surfaces are especially critical areas. For the surface, a careful inspection of the edges for chips and the coated areas for cracks or bubbles is recommended. Quality may vary in IKEA stores, so simply compare similar models.
joroti
10 Dec 2020 11:45
Stability test: gently press on the corners and wiggle the panels. Feel the edges with your finger to check if they are smooth and free of roughness. Drawers should open and close smoothly.
BELLA34
10 Dec 2020 12:02
Torsten45 schrieb:
In IKEA stores, quality can vary
That’s exactly what I have noticed too. It’s better to look at several pieces, if possible. That way, you can find the best example.
piflo
10 Dec 2020 12:30
Fapaolo3 schrieb:
How can you test the stability without damaging the piece of furniture?
Are you asking because you’re worried about breaking something? Here’s how I see it: applying moderate pressure and gently shaking won’t cause any harm but will definitely help you identify potential weaknesses. When checking surfaces, it’s best to feel along the edges, including the top and bottom, to spot any manufacturing flaws.
nonere
10 Dec 2020 13:10
In addition to the previous advice, I would like to address the topic of packaging. In many cases, damage occurs during transport. Check the packaging seals for any signs of damage and ask if you can at least partially inspect the furniture unpacked on site. This reduces the risk of taking home items that are already damaged.
