I recently managed to set up my Malm furniture with wood veneer again after an extended renovation. Now I’m facing the issue that the surfaces are partly covered with fine renovation dust and also have some light paint or adhesive residues.
Since I don’t want to damage the surfaces, I’m looking for the best way to gently but effectively clean Malm-style surfaces after renovation.
I’m especially interested in whether certain cleaning products or techniques are particularly suitable for cleaning veneered surfaces like these, so that neither the veneer nor the protective layer gets damaged.
Does anyone have experience with removing renovation dust, paint spots, or glue residues from Malm furniture and could possibly recommend a step-by-step procedure or point out common mistakes? Thanks in advance!
Hello Gigliola,
I am familiar with this situation; renovation often leaves dust that is difficult to remove, especially on wood. It is important to handle such furniture carefully, as it is easy to cause damage.
I once had adhesive residue on my Malm; warm water with mild dish soap and a soft cloth helped me. But be cautious—not too wet. If there are paint stains, I tried a special furniture cleaner that shouldn’t be too harsh.
How severe are the residues? Maybe you have already tried something?
boelnu schrieb:
If there are paint stains, I have tried using a special furniture cleaner that is not too harsh.Thank you for the tip. The paint stains are probably from slight splashes of wall paint that got on during glazing. So really only small, localized spots.
I would prefer not to use chemical products without a proper recommendation.
Meoru schrieb:
Adhesive can be carefully removed with isopropanol, but use sparingly and test for compatibility.That sounds good. Do you have experience with the compatibility of isopropanol on veneered surfaces? I’m concerned it might cause drying out or discoloration.
I always find it problematic to generalize when dealing with such surfaces. Veneer and the lacquer or protective layer applied on top react very differently.
That’s exactly the point. Isopropanol can indeed damage the surface and dull the veneer. I would recommend mechanical, very gentle methods instead—such as carefully soaking with a slightly damp cloth and avoiding too much rubbing.
Also: How thick and durable is the protective layer on your Malm? Has it been sealed with clear lacquer or only oiled? This makes a big difference for the right approach.
Gigliola schrieb:
I’m concerned that drying out or discoloration might occur.
To achieve the best possible result, I recommend first determining the exact type of surface: Original Malm furniture made of veneered MDF or particleboard usually has a melamine coating, which is quite durable.
Steps for cleaning after renovation:
1. Remove dust: Instead of dry wiping, I recommend lightly dampening a soft microfiber cloth first to properly capture the fine renovation dust.
2. Treat stubborn spots with a mild detergent solution using a soft cloth. Important: Do not use abrasive cleaners.
3. Paint stains can sometimes be removed depending on the type of paint with a glass cleaner (such as an alcohol-based one), but test carefully!
4. Adhesive residues can be removed with a small drop of isopropanol, but always test first in an inconspicuous area!
Be sure to test in a hidden corner before treating larger areas to avoid color changes or dullness.
How old is your piece of furniture, and did it already have visible damage before the renovation that might now be more noticeable?
