I have a rather specific question regarding furniture care: Are there any specially designed cleaners for the surface of Ikea Malm furniture? I ask because I have read that some furniture surfaces – especially those with lacquer or special veneers – can be sensitive to the wrong cleaning products.
My Malm dresser has a white, smooth surface that I want to keep clean as gently as possible, without making it look dull or damaged.
Can anyone tell me if there are cleaners specifically formulated for these Malm surfaces? Or are standard household cleaners sufficient?
I look forward to your tips and experiences!
derrick3417 May 2023 08:37Hello,
There are no specific cleaners only for Malm surfaces. Regular mild all-purpose cleaners or a damp cloth are usually sufficient.
Avoid harsh products with solvents, as they can damage the surface.
Why should there be specially formulated cleaners for Malm furniture?
As far as I know, Ikea does not use any unusual materials that require special care. The surfaces are mostly melamine-coated or finished with paint.
That also seems reasonable to me. However, the question remains how sensitive the veneers really are to solvents or abrasive substances.
Are there reliable sources or practical experience that specifically warn against or recommend certain cleaners?
derrick34 schrieb:
Normal mild all-purpose cleaners or a damp cloth are usually sufficient.
I would like to add that most Ikea Malm surfaces are made of melamine-coated fiberboard. This surface is quite durable but sensitive to strongly alkaline or acidic cleaners as well as harsh solvents.
Therefore, I recommend:
- Removing dust with a soft cloth
- Using a damp microfiber cloth with a mild dish soap solution
- Avoiding abrasive cleaners or aggressive chemicals
There are no specific "special cleaners" from Ikea designed exclusively for Malm.
If you have tougher stains, choose the mildest possible products and test them on an inconspicuous area first.
Additional Information:
I have gained some experience in caring for IKEA furniture with melamine-coated surfaces. These surfaces are generally quite resistant to water and mild cleaners, as melamine is a hard, scratch-resistant plastic layer.
However, there are some important points to consider:
1. Do not use solvent-based cleaners (no acetone, alcohol, or nail polish remover), as they can damage and bleach the surface.
2. Avoid microfiber cloths with sharp edges or those containing abrasive materials.
3. For removing greasy stains, I recommend mild soapy water, such as a pH-neutral dish detergent.
4. Always wipe again with clean water after cleaning and dry the surface to prevent streaks or water spots.
Some brands offer special plastic or furniture care products marketed as all-purpose cleaners for delicate surfaces. These might also work on Malm furniture but are not strictly necessary.
Another option is a light spray-and-wipe cleaner, for example, a fragrance-based one without harsh chemicals. It is important to apply it to the surface rather than letting it drip and to wipe promptly.
May I ask what type of stains you are dealing with? That way, I can provide more targeted advice.
