I’m currently facing the challenge of how to apply self-adhesive films neatly onto Pax surfaces. Specifically, I want to make sure the films neither bubble nor peel off at the edges. I have furniture with smooth, coated fronts where the film should adhere as smoothly and permanently as possible. Unfortunately, I haven’t found any good guides that focus specifically on the smooth surface of Pax.
I would appreciate any tips on how to best prepare and apply the film, whether tools like a squeegee should be used, which techniques have proven effective, and how to work as bubble-free as possible. Advice on cleaning the surface before applying the film or tricks in case bubbles do appear would also be extremely helpful.
Thank you in advance!
Hello Marzar43,
First of all, I think it’s great that you’re putting thought into how to do this properly. My tip for applying adhesive film to smooth Pax surfaces is to work very carefully. This means:
- Thoroughly clean the surface and make sure it’s free of grease, for example with a degreaser or isopropanol.
- Then peel off the film slowly, ideally not all at once, but apply it step by step.
- A plastic squeegee is very helpful to press the film evenly and avoid bubbles.
- If you get small bubbles: usually you can carefully smooth them out, otherwise gently prick them with a sharp needle, being careful not to damage the film.
It’s also important to apply the film at room temperature so that it is more flexible.
I hope this helps you a bit!
It’s interesting that the discussion often focuses only on using a squeegee and cleaning the surface. However, it raises the question of how much the surface texture of the Pax coating actually affects the adhesion of the film.
Does anyone have concrete experience with differences between various types of films or adhesive qualities on Pax? Because it could be that even the very smooth surface holds the film better or worse depending on areas with slightly more texture.
Additionally, it would be interesting to have a discussion about whether using a heat gun for post-treatment of the film after application is really effective — this is often recommended, but I can hardly find any measurable evidence. How do you handle this?
BLAKEO schrieb:
Interesting that people here often only talk about using a squeegee and cleaning the surface.I completely agree. I even find it questionable whether the Pax surfaces should be covered with adhesive film at all. People often talk about ‘clean adhesion,’ but honestly: who can guarantee that the film won’t start peeling at the corners after a few years?
I see it more as a temporary fix, a) because films age over time, and b) because the factory finish on Pax is designed for durability, but not necessarily for adhesive films. Not to mention the risk of damaging the surface when removing the film.
So, if you want to be sure, you should either paint it or choose another solution. But just sticking a film on and hoping for the best is not advisable.
Laure57 schrieb:
A plastic squeegee is very helpful for pressing the membrane evenly and avoiding bubbles.Thank you very much, that helps me a lot. One more question: Do you have any tips on the best way to position the membrane? I’m worried that once it’s positioned, I won’t be able to adjust it, at least not without affecting the adhesive properties.
Are there smart techniques that allow a bit of play, or should you press firmly right away, starting at the top and then working your way down slowly? What works best for such large membranes?
