Hello everyone, I would like to start a discussion about the best ways to clean Malm surfaces without damaging them or leaving unsightly residues. This specifically concerns the light oak wood with its characteristic matte, slightly porous surface. I have noticed that conventional cleaning agents sometimes cause streaks or spots. Some recommend special furniture cleaners or natural products, while others swear by home remedies. What are your experiences? Which cleaning methods really work best, especially to preserve the natural look and feel? Which products or techniques should be avoided? Thanks for your tips!
V
vincent463 Sep 2021 09:05Hello sau64, I completely understand how frustrating it is when the cleaning results are not satisfactory. I had a similar experience with my Malm dresser. I tried many methods back then, including experimenting with different soap solutions. I believe it’s especially important not to make the surface too wet and to use a soft cloth. Have you perhaps tried cleaning with just a slightly damp microfiber cloth? For me, that usually worked quite well without leaving streaks.
Hello sau64, it’s interesting that you mention the light oak wood look of the Malm surfaces, which are known for their somewhat sensitive, matte lacquer finish. I recommend cleaning them in several precise steps. First, remove dust with a dry, soft cloth. Then use a mild cleaning solution made from very diluted dish soap – about a few drops of detergent in one liter (1.06 quarts) of lukewarm water. It is important to only slightly dampen the cloth; it should not be wet, to avoid water marks. After wiping, immediately polish with a dry microfiber cloth to remove moisture and residues. I would completely avoid aggressive cleaners, abrasive cloths, or oils, as these can damage or discolor the matte surface. Another point: for stains, clean only the affected area rather than letting it dry over a large surface. If stains are stubborn, you may need to use a professional cleaner designed for matte lacquered wood; it’s best to test this first in an inconspicuous spot. Do you use the furniture in high-traffic areas, or are they more decorative pieces?
V
vincent463 Sep 2021 10:45kibutar schrieb:
Only slightly damp cloths and immediately dry by polishingThat matches my experience. I once worked with cloths that were too wet, and it did make the surface somewhat dull. Another tip from me: After cleaning, I let the furniture dry with the window fully open to prevent moisture buildup.
