ᐅ How do I repair small scratches on IKEA Brimnes surfaces?
Created on: 8 Oct 2024 09:17
Leik51
Leik51
8 Oct 2024 09:17
I have noticed some small scratches on the surface of my IKEA Brimnes dresser. Since it is a painted MDF board with laminated surfaces, I am unsure how to best repair these scratches without affecting the appearance or damaging the surface.
Does anyone know effective methods or products to easily and reliably fix small scratches on Brimnes furniture?
It is important to me that the repair is as invisible as possible and does not leave any residue or color differences.
I look forward to your tips and experiences!
Marcellela
8 Oct 2024 09:45
try using a furniture repair marker in the matching color. This often works quite well for minor scratches.
Filippo
8 Oct 2024 11:02
Hello Leik51,
I follow a somewhat more systematic approach when repairing small scratches on laminated surfaces like those of the Brimnes series. First of all, the damaged area should be cleaned very thoroughly to ensure that dirt or grease does not affect the adhesion of any subsequent products. Isopropanol on a lint-free cloth works best.
Depending on the depth of the scratch, you can try the following steps:
- For very fine or superficial scratches, a furniture repair marker or wax crayon made specifically for furniture surfaces works well. It is important that the color matches the white or the color of the Brimnes surface as closely as possible, otherwise the repair will be noticeable.
- For somewhat deeper scratches, you can carefully touch up with white acrylic paint applied with a very fine brush. Alternatively, there are special markers designed for furniture surfaces. Always apply thin layers in multiple coats.
- For a particularly clean finish, I recommend lightly sanding the repaired area with very fine sandpaper (grit 1000 or finer) after the paint has dried, to smooth the edges.
- Finally, you can apply a thin clear protective layer (e.g., matte clear varnish from craft supplies) to seal the surface and make it more resistant to further damage.
A quick question: How deep are the scratches approximately, and is the surface more matte or glossy? This affects the choice of products.
I hope this helps you for now.
Leik51
8 Oct 2024 11:46
Filippo schrieb:
Quick question: How deep are the scratches approximately, and is the surface more matte or glossy? That affects the product choice.
Thank you for the detailed explanation. The scratches are actually quite superficial, so no deep grooves, more like small scrapes. The surface is matte white, not glossy.
That suggests a repair pen might not always be sufficient. I will check if I can find a suitable acrylic marker.
Are there any specific brands or products you would recommend for this type of repair? I haven’t seen a really good selection at the hardware store so far.
blapau
8 Oct 2024 13:29
For matte surfaces like those on Brimnes, I generally recommend being very cautious with color choices and starting with small tests on an inconspicuous area.
A tip: Furniture care sticks based on wax often appear glossier and are therefore less suitable for matte surfaces, as they can alter the appearance. Acrylic markers or very thinly applied acrylic paint work better here, but without any thickening agents.
Also, after treatment, you should avoid polishing too vigorously, as this can change the finish.
If you want, you can buy a set of different shades of white in advance – some art supply manufacturers offer matte acrylic paints that work well as repair materials.
Elijah42
8 Oct 2024 14:57
I often use an old gear or a cotton cloth with a bit of furniture polish to clean and lightly conceal small scratches. This works surprisingly well for relatively shallow scratches.
