ᐅ Does anyone have experience with epoxy sealing for KALLAX surfaces?
Created on: 19 Jun 2021 14:23
Lutzna
Lutzna
19 Jun 2021 14:23
I am considering treating the surfaces of my IKEA KALLAX shelves with an epoxy resin coating. The main goal is to create a durable, glossy, and water-resistant surface that can withstand scratches and stains well.
Has anyone had personal experience with epoxy coatings on KALLAX or similar MDF-based furniture? I am especially interested in:
- How well does the resin adhere to the typically lacquered or melamine-coated surface?
- Are there any specific preparations that must be followed?
- What is the realistic curing time, and how durable is the surface in everyday use?
I look forward to hearing your experiences and tips!
JORGERON
19 Jun 2021 14:46
Epoxy can be applied on KALLAX, but it must be sanded beforehand to ensure proper adhesion. Curing usually takes 24 to 48 hours. The surface becomes very durable and water-resistant.
daalessio
19 Jun 2021 15:08
It is important to thoroughly clean the surface and lightly roughen it. Melamine and paint are usually smooth, so sanding with fine sandpaper (grit 240) provides the necessary adhesion base. Be sure to remove all dust afterward to prevent inclusions. Epoxy resin cures fully depending on the product within 24 to 72 hours, and sometimes multiple layers are advisable to achieve optimal protection.
Lutzna
19 Jun 2021 16:12
JORGERON schrieb:
Epoxy can be applied on KALLAX, but make sure to sand it beforehand, otherwise it won’t adhere properly.
Thanks, sanding was already on my list; I just wanted to know if the material of KALLAX (i.e., MDF with a melamine coating) is generally compatible with epoxy.
daalessio schrieb:
Melamine and lacquer are usually smooth, so sanding with fine sandpaper (grit 240) provides the necessary adhesion surface.
That makes sense. I usually use grit 400 for wood, but I’ll carefully test grit 240 on an inconspicuous spot.
What I’m also wondering: with thicker epoxy layers, heat buildup can occur. Have you experienced any issues with this, especially on such thin material like KALLAX?
JORGERON
19 Jun 2021 16:45
Heat buildup can indeed be an issue with layers that are too thick. Pour a maximum of about 2-3 mm (0.08-0.12 inches) per layer, then wait until it is fully cured. Otherwise, the resin may turn “yellow” afterwards or form bubbles.
pikin
20 Jun 2021 09:02
Summary of epoxy sealing on KALLAX:
1. Adhesion: Melamine or lacquer surfaces are smooth and difficult to bond. Proper mechanical roughening (sanding, grit P240-P320) is essential since epoxy resin does not chemically bond with melamine.
2. Preparation: After sanding, clean thoroughly (free of dust and grease). Isopropanol is a good choice.
3. Application: To avoid heat buildup, apply thin layers in several steps.
4. Curing: Typically 24 to 72 hours, depending on the product and ambient temperature.
5. Due to the material properties, some flexibility of the substrate must be expected. KALLAX MDF is not solid wood, so it is advisable to avoid applying thick layers or subjecting the furniture to extreme stress to prevent cracks or delamination.
6. Final result: When done correctly, epoxy seals very well against moisture, scratches, and stains; the surface is glossy and highly durable.
