ᐅ How do you secure a Pax wardrobe on uneven floors?
Created on: 20 Sep 2021 10:23
Plo36
Plo36
20 Sep 2021 10:23
Hello everyone, I recently bought a Pax wardrobe and now face the challenge of securely fixing it on an uneven floor. The irregularities mainly consist of slight height differences of up to 1.5 cm (0.6 inches) across the surface where the wardrobe will be placed. My question is: what is the best way to secure a Pax wardrobe on uneven floors so that it stands firmly, doesn’t wobble, and maintains its load capacity? Are there specific techniques, materials, or additional fasteners you would recommend? I am also interested to know whether the wardrobe feet should be adjusted accordingly or if other measures are more effective. Thanks a lot for your advice!
cassandra
20 Sep 2021 11:07
The Pax wardrobe from IKEA is generally designed to be installed on level floors. For uneven floors, the following approach is recommended to ensure stability:
- First, check the floor with a spirit level to determine the exact unevenness.
- For height differences up to approximately 2 cm (0.8 inches), adjustable furniture feet can be used, placed under the wardrobe and individually adjusted.
- Alternatively, plastic furniture gliders or leveling wedges can be used to compensate for minor unevenness.
- It is also advisable to secure the wardrobe to the wall, which significantly increases stability and prevents any wobbling.
It is important that the chosen accessories can safely support the weight of the wardrobe and its contents. For severe unevenness, consider improving the subfloor (e.g., using an OSB board as a level base).
Kurtis5
20 Sep 2021 11:42
I would recommend adjustable furniture feet and definitely securing the cabinet to the wall. This way, everything remains stable.
kloreo
20 Sep 2021 12:15
For minor floor irregularities, use leveling wedges made of wood or plastic. Alternatively, adjustable feet with a screw thread work well.
reoleon47
21 Sep 2021 09:13
Super interesting topic! I have my Pax wardrobe standing on a wooden floor with slight unevenness. What helped me was attaching adjustable feet at the bottom and then fixing it to the wall – now it’s rock solid! If you’re unsure about the feet, definitely give this a try. It provides stability, especially if kids are running around, as they can easily tip the wardrobe otherwise! Good luck!
cassandra
21 Sep 2021 10:44
reoleon47 schrieb:
What helped me was screwing on adjustable feet at the bottom and then attaching it to the wall – now it’s rock solid!
To add some technical details: For wall mounting, the included brackets and anchors are typically used, which should be installed into a load-bearing wall. If possible, it’s best to fix them directly into a wall stud or masonry to ensure a secure attachment. The adjustable feet allow for fine-tuning and compensate for slight unevenness in the floor.
