ᐅ How can I secure IKEA PAX wardrobes to wooden floors without causing damage?
Created on: 9 Feb 2023 08:23
MOHAMEDNAU
I am planning to secure an Ikea Pax wardrobe to wooden floors but am unsure of the best way to do this without damaging the floor. The challenge is that I want to firmly fix the wardrobe to prevent tipping or sliding, especially in homes with young children. At the same time, I absolutely want to avoid scratching or damaging the wooden floor with screws, anchors, or other fastening methods.
Does anyone have experience or practical tips on how to attach an Ikea Pax to wooden flooring without harming it? Are there specific fastening materials or techniques (e.g., protective pads, special screws, or alternative methods) that have proven effective? I would greatly appreciate any suggestions, especially if there are options that combine both non-residue removal and stability.
Thank you in advance!
Hello Mohamednau,
Ianlau’s suggestion to use weights is quite practical – I’ll briefly explain:
- Weights should be placed at the bottom of the cabinet, for example, with sandbags or filled containers that won’t slip.
- It is important not to place them directly on the wooden floor but to use a non-slip mat (felt or rubber) underneath.
- The weights can be positioned on the base of the cabinet to effectively prevent tipping.
- Make sure to use the right amount of weight – too heavy can unnecessarily strain the floor.
If you prefer a technical solution: you can also use tension rods between the cabinet and ceiling to stabilize the cabinet without drilling. However, this is somewhat more complex.
Summary:
- Use weights at the bottom with a protective mat
- Always ensure securing the cabinet does not interfere with the function of the compartments
- Alternative: wall anchors or ceiling tension rods
I’m happy to provide more advice!
Summary:
MOHAMEDNAU schrieb:
What kind of weights would be suitable, and how can I secure them safely without damaging or altering the furniture?I used sandbags made from fabric bags, which were simply placed flat inside at the bottom. It’s important that they cannot move, so it’s best to pack them tightly together in the same compartment.
MOHAMEDNAU schrieb:
I have some compartments and drawers inside that need to be used. What kind of weights would be suitable, and how can I secure them safely without damaging or altering the furniture?Hello again,
Adding to my previous comments: To ensure the weights stay firmly in place, you can use a large, heavy box or a (hermetically sealable) container that can be placed on the bottom of the cabinet. This container can be opened when needed and also provides flexibility. The drawers remain functional because the weights at the bottom of the cabinet don’t obstruct the compartments above.
If you are handy, you could also install a small bracket (e.g., a wooden frame) in the lower corner of the cabinet to hold the weights and prevent them from sliding.
Basically, you should always use a protective layer between the floor and the weights to protect the surface. This way, you achieve good stability and protect your wooden floor—without having to screw into the floor.
Good luck with your project!
