Hello everyone, I am currently planning the setup of my home office and would like to use a cabinet from the IKEA Platsa series. Since this system is very versatile, I am wondering about the best approach to plan the cabinet in a way that is both functional and space-efficient. Specifically, I am interested in which dimensions and modules work well together, how to optimally arrange the interior compartments for binders, electronic devices, and other office supplies, and what to pay attention to during planning in terms of stability and later assembly. Are there any proven methods or planning tips that can help reduce effort and achieve an efficient result? Thanks in advance for any helpful advice!
I designed my office cabinet using Platsa with a depth of 60cm (24 inches) and I’m really happy with it! Especially for the printer, I was able to create a separate cutout as a storage compartment, which makes access much easier. My tip: use open shelves for frequently used devices and combine them with doors for folders – it looks smart and stays organized!
retau schrieb:
Use open compartments for frequently used devices and combine them with doors for folders This works really well, especially for cabinets that should also look good. And hey, a bit of airflow for electronics is worth its weight in gold – otherwise, things quickly overheat 🔥😂!
I’ve also brightened up my PLATSA cabinet with colorful doors, which really lifts the mood in the otherwise dull office.
That's true, the combination of open and closed storage makes a big difference. And the PLATSA modules are so versatile that you can rearrange them however you like. For offices, I especially like using compartments with different heights in case a thicker binder or an unusual device needs to fit in. It's a bit like Lego for adults 😄!
Laukau5 schrieb:
What cabinet height do you have in mind? 192 cm (75.6 inches) is usually comfortable, but custom adjustments can improve space utilization.The ceiling height in the office is 2.35 m (7 ft 8.5 in), so I tend to prefer the maximum height to make the best use of the space. However, I’m concerned that the upper compartments might become hard to reach. What do you think? Is it better to combine several low modules side by side, or to go for a tall cabinet and use a step ladder?
JORGERON schrieb:
For technical equipment, I use 60 cm (24 inches) depth because otherwise there isn’t enough space and ventilation inside the cabinet.Here I’m facing space issues since the room is too narrow for 60 cm (24 inches) depth at full width. Are there any experiences with good solutions for this?
The consideration of maximum cabinet height is pragmatic from a space utilization perspective, but the following aspects should be taken into account:
- Accessibility: Compartments above approximately 180 cm (6 feet) are difficult to reach and require a sturdy ladder or step stool.
- Alternative: Lower cabinets that can serve as room dividers or be combined with top modules.
- For equipment with a depth of 60 cm (24 inches): If the room is too narrow, consider placing a separate, deeper module for technical devices either beside or under the desk.
What devices are planned? Printer, NAS, charging stations? It often makes sense to supplement the cabinet with a modular technology tower.
Finally, I recommend simulating the design with precise measurements in a 3D tool to evaluate the impact of different combinations.
