danjadyn4116 Jun 2018 08:37Good morning everyone, I have a rather specific question: Who can give me tips on how to effectively remove stubborn stains from the surfaces of my BILLY bookshelf from IKEA without damaging the finish? The surfaces are made of waterproof melamine laminate, but I have various types of stains – from dried glue to ink and food stains. If I clean too aggressively, scratches or dull spots appear quickly, which I naturally want to avoid. What methods, cleaning agents, or household remedies have you found effective for removing these kinds of stains completely while protecting the material? Advice on dosages, exposure times, or special techniques is also very welcome. Thanks in advance for your expertise and help!
To remove stubborn stains on BILLY surfaces, I recommend the following based on the characteristics of melamine coatings: In general, avoid aggressive abrasives or highly abrasive cleaners, as they can damage the surface. For ink or adhesive stains, isopropanol (rubbing alcohol) often works well; apply it gently with a soft cloth and then wipe off with clean water. Do not rub, but dab instead. For food residues, mild dishwashing detergent solutions are usually sufficient, possibly aided by the soft side of a plastic sponge. Particularly set-in stains can be treated with a paste made from baking soda and water: apply the paste briefly, leave it on for a maximum of 5 minutes, and then gently wipe it off. Another tip is a solution of vinegar essence diluted with water at a ratio of 1:3, but use this sparingly, as strong acids can damage the surface. If in doubt, test first in an inconspicuous area before applying it broadly.
ladali schrieb:
For ink or adhesive stains, isopropanol (rubbing alcohol) is often effective. It should be applied carefully with a soft cloth and then wiped off with clean water.Isn’t that somewhat risky? Isopropanol can affect melamine coatings if used too often or improperly, potentially dulling the finish or even causing slight discoloration. Are there reliable user experiences or technical recommendations from IKEA itself regarding this? Or are other solvents considered safer? I think unless explicitly approved by the manufacturer, it’s better to use mild cleaning agents.
Jamalli schrieb:
Isn’t that a bit risky? Isopropanol especially can affect the gloss or even cause slight discoloration on melamine coatings if used too often or improperly.That is a valid point. My recommendation to use isopropanol is meant for rare and careful application. When used occasionally and spot-treated with good dilution, the risks are minimal, especially since it evaporates quickly and leaves no residue. For large areas or sensitive surfaces, however, it is better to use mild cleaners, such as pH-neutral all-purpose cleaners without solvents.
IKEA generally advises cleaning BILLY and similar furniture with a damp cloth and mild soapy water, avoiding strong chemicals or solvents. The company does not explicitly provide exceptions, so it is always recommended to test on an inconspicuous area first.
To complement the previous information: The BILLY furniture is coated with a melamine resin finish, which offers high scratch and moisture resistance but is sensitive to abrasive influences. Chemical agents can also cause surface damage depending on their concentration and exposure time.
I recommend a two-step cleaning process:
1. Clean with a soft microfiber cloth and a mild dish soap solution (e.g., 1 drop of dish soap per about 1 liter (1 quart) of water).
2. For stubborn stains: Make a paste from baking soda and water – this acts as a gentle abrasive but is soft enough to avoid damage. Apply the paste to the stain, let it sit for no more than 3 to 5 minutes, and then wipe off with a damp cloth. Afterwards, rinse the surface with clear water and dry with a clean cloth.
Important: Do not rub too hard, as this can cause micro-scratches. Also, avoid aggressive solvents such as acetone, turpentine, or high-concentration alcohol.
To prevent permanent changes to the surface, I recommend always testing any cleaning product on a small, hidden area first. Finally, for ink stains, special eraser-like cleaning sponges (melamine-based sponges) can be effective, but use caution as heavy scrubbing can also leave dull marks.
When did these stubborn stains appear for you, and what kind were they? Pure food stains or rather adhesive/paint residues?
