ᐅ Billy Shelf - Easy to Dismantle.
Created on: 15 Jun 2024 10:17
Rolen
Rolen
15 Jun 2024 10:17
I am currently facing the challenge of having to disassemble a Billy bookshelf and would like to know how to do this as easily as possible and without causing any damage.
My main concern is safely removing the individual shelves and side panels so that I can transport the furniture in a space-saving way and later reassemble it.
Are there any special tips for IKEA Billy bookshelves, for example regarding the attachment of the back panel or the dowels, that I should be aware of?
I have some experience with furniture assembly, but I often get worried about breaking something during disassembly.
What are your best tips and perhaps recommendations for tools? Thanks in advance for any advice!
lisku
15 Jun 2024 10:42
Hi, it is best to use a Phillips screwdriver for the screws. The back panel is usually only stapled; carefully remove the staples with a putty knife. Carefully pull out the anchors, preferably with pliers.
Domau0
15 Jun 2024 11:05
Hello Rolen,
when disassembling a Billy bookshelf, it is important to proceed systematically to avoid damaging any parts. It is best to start by removing the back panel. This is usually held in place by small clips, which can be carefully loosened with a flat putty knife or screwdriver. Work around the edges to avoid damaging any clips.
Next, I recommend unscrewing all the screws that connect the side panels to the shelves. IKEA often uses so-called Minifix connectors and wooden dowels. Minifix screws can be removed with a Phillips screwdriver, while removing the wooden dowels should be done gently to avoid splitting the wood.
A tip: make notes or take photos of how everything is assembled beforehand. If you plan to reassemble the bookshelf later, this will make it much easier to identify the parts.
Can you say whether you have a standard model or a version with glass doors or extra reinforcements? That would help with specific advice.
Rolen
15 Jun 2024 11:37
Thanks in advance for the initial tips!
The shelf is a standard Billy with the classic wooden back panels, no doors.
The idea of systematically tightening and loosening screws sounds sensible; this helps avoid pressure marks or cracks.
What I’m also particularly interested in: When pulling out dowels and wooden sticks, I’ve often had problems with slipping and splitting. Is there a recommended technique to prevent this?
And what are your thoughts on applying heat (e.g., a hairdryer) to loosen glue joints, if present?
benon
15 Jun 2024 12:21
Hello Rolen,
Your concern about the dowels and wooden sticks is justified. It’s best to use a good pair of pliers with a fine, textured grip to carefully pull out the dowels. You can gently tap the side to loosen them while pulling slowly and straight.
Regarding heat: A hairdryer can help if the wood is stuck at glued joints, but Billy shelves are usually only mechanically connected. Be careful with too much heat, as it can warp the wood or damage the finish.
If the joints are very tight, I would rather try gently prying with a plastic wedge instead of using heat to avoid any damage.
I hope this helps you!
te-min
15 Jun 2024 13:04
Rollers,
You can also wrap the wall plugs with tape and then carefully pull them out to prevent any splintering.
Regarding the back panel: use a putty knife to lift the clips gently and carefully pry them away. Do not use a hammer.
