ᐅ How can I repair damaged wooden parts of Ikea PLATSA furniture?
Created on: 15 Jan 2020 09:13
majachen
I have some damaged wooden parts from my Ikea Platsa system here. Unfortunately, the damage is quite significant – there are broken corners, surface scratches, and some chipped edges. Since I would like to restore these parts, my question is: How can I repair or reconstruct these damaged wooden pieces as accurately and durably as possible?
It is especially important to me that the surface texture and color are largely preserved or at least well restored, as otherwise the repair attempt becomes immediately noticeable. Are there any proven methods for filling and restoring the decorative veneer, or could replacement parts from Ikea’s service be the better option?
I look forward to your experiences and tips!
Ianlau
15 Jan 2020 11:47
majachen schrieb:
Are there any special wood fillers recommended for smooth surfaces that adhere well to foil?
Yes, there are wood fillers based on synthetic resin that stick better to smooth surfaces and are more flexible than traditional wood fillers. They fill scratches and holes well and can be sanded.
For sanding, I recommend fine sandpaper with a grit of 180 to 240 to carefully smooth the repair and refine the transitions to the original surface.
For larger edge damages, it often helps to rebuild the missing shape using wood glue and veneer strips or custom-cut plywood pieces, then smooth the build-up with filler. This way, you can restore the shape before treating the surface.
Colored pencils or acrylic paints can be used to touch up the color in thin layers.
If you’re interested, I can provide a short step-by-step guide.
majachen
15 Jan 2020 12:14
Ianlau schrieb:
If you’re interested, I can write a short step-by-step guide for you.
Yes, please, that would be really helpful. Thank you!
I also appreciate your tip about reconstructing the form. Restoring the shape is actually the biggest challenge for me because the foil can’t simply be reapplied. Did you mean that the decorative foil from Platsa can be replaced somewhere easily with little effort, or is that rather difficult to impossible?
Ianlau
15 Jan 2020 12:46
Here is a rough step-by-step guide for PLATSA wooden parts:
- Assess the damage: note broken corners, scratches, and chipped edges
- If a large section is missing, rebuild it using wood glue and small wood pieces (e.g., thin plywood scraps)
- After the glue has dried, fill the repaired area with high-quality synthetic resin-based filler and shape it accordingly
- Once dry, carefully smooth the filler with sandpaper (grit 180-240)
- Apply color touch-ups using a wood repair or furniture marker, ideally in several very thin layers
- Finally, apply a matte or satin finish to protect the surface and improve appearance
Regarding purchasing the original veneer film: Ikea does not sell it separately. You might try experimenting with fine self-adhesive furniture films, but matching the fit and surface texture precisely can be difficult.
For both appearance and durability, repair with filler and paint is usually the best solution.
Linavin
16 Jan 2020 08:22
I think it is important to critically consider how sensible the repair is compared to replacement.
Ianlau schrieb:
Ikea does not sell them individually.
This means that if the damage is not minimal, you might end up putting in a lot of effort to achieve an aesthetically acceptable repair – without any guarantee of durability.
Therefore, I would recommend always first considering the value and age of the furniture. Especially with PLATSA, which is rather inexpensive and works on a modular system, a new purchase could be more practical, particularly if larger areas are affected.
Of course, I understand the desire for sustainable repair, but sometimes the effort simply outweighs the benefit.
bente
16 Jan 2020 10:15
Linavin schrieb:
I would therefore recommend always considering the value and age of the furniture first.
That is certainly true, especially when disposing of or replacing furniture safely.
On the other hand, I see repair as a form of appreciation or a project that breathes new life into a piece of furniture. In my experience, repaired furniture tells its own story and is often valued even more than new items.
Ultimately, it is also a matter of attitude and personal expectations regarding the outcome. For me, it often makes sense to repair – even if the result isn’t perfect.
majachen
16 Jan 2020 11:02
That’s a very good point, thank you for that! I have been using the PLATSA pieces for nearly four years, and they are still fully functional—I mainly want to repair them for aesthetic reasons because they play an important role in my interior design.
I will try Ianlau’s instructions; I see a good balance there between repair effort and outcome.
One quick question for everyone: Does anyone have experience using color-matched paint on laminated surfaces? Does it adhere well, or could it possibly cause the laminate to peel off? That would, of course, be problematic...
