ᐅ Are there compact IKEA PLATSA solutions suitable for small apartments?
Created on: 13 Dec 2024 08:17
Josh68
Are there compact IKEA PLATSA solutions for small apartments?
I will soon be moving into a very small apartment, which mainly consists of a single room. My challenge is to create as much storage space as possible without the furniture feeling too bulky or taking up too much space. IKEA PLATSA seems very flexible and customizable, but I wonder if the system actually offers good, practical, and compact solutions for very small rooms.
Can you share your experiences regarding layouts, combinations, or designs that have worked well? I am especially interested in things like built-in cabinets with storage that blend seamlessly into the room, as well as options that serve both as storage and as a design feature.
It would also be helpful to know if the PLATSA system is easy to assemble for someone with little experience in furniture assembly, and if it is sturdy enough for everyday use in a small apartment.
I appreciate any tips and advice!
Hello Josh68,
to give you a well-informed recommendation: What is the floor area of the apartment, and are there any specific constraints such as radiators, doors, or windows? Precise planning depends heavily on the existing structural conditions.
Platsa cabinets are available in the following standard depths: 20 cm (8 inches), 35 cm (14 inches), 55 cm (22 inches). For small rooms, I recommend 35 cm (14 inches) to avoid taking up too much space.
Important for installation:
- Make sure to measure the walls very accurately, including any irregularities like slants or alcoves.
- If you are renting, check whether wall anchors and drilling are permitted. For flexible solutions, there are wall spacers and mounting aids available.
Combining several smaller modules instead of one large cabinet allows for better adaptability.
One more question: Do you prefer especially smooth-running drawers or doors? PLATSA offers different options, such as push-to-open or soft-close, which require different installation and maintenance.
Dilen schrieb:
PLATSA is available in the following standard depths: 20 cm (8 inches), 35 cm (14 inches), 55 cm (22 inches). For small rooms, I recommend 35 cm (14 inches) to avoid taking up too much space.Exactly! A depth of 35 cm (14 inches) works well for me too. I can also add that I use white fronts, which makes the room feel much brighter and more open. 🙂
Dilen schrieb:
If you’re renting, check whether anchors and drilling are allowed.A very important tip, especially for small and older apartments. I’ve often used nails instead of anchors or tried adhesive hooks for wall cabinets. That usually works well!
Give it a try and don’t stress – PLATSA is really a great solution!
Thanks to everyone for the tips already!
To get back to Dilen: The apartment is just under 25 m² (270 sq ft), with small recesses near the windows and doors as well as a radiator that reduces the available wall space. It’s a rental with white walls. Drilling and using anchors are allowed, but I want to make as few holes as possible since I will be moving out again in August.
The idea of wall cabinets sounds good; that way I could make better use of the remaining wall space.
As for the installation: I have basic knowledge but not much experience, so a few tips on especially tricky mounting steps would be really helpful.
Which cabinet fronts remain easy to clean and durable after long-term use? Has anyone had bad experiences with certain paints or finishes?
Josh68 schrieb:
Drilling holes and using wall plugs is allowed, but I want to minimize holes since I’ll be moving out again in August.This is a very important point. I had setbacks before because I made too many holes, and it was costly when moving out.
Perhaps freestanding modules placed against the wall would be a good option, as they stand securely without drilling? Some PLATSA units can also be used as room dividers, visually splitting the space.
Josh68 schrieb:
Which fronts remain easy to clean and durable after long-term use?In my opinion, lacquered fronts are easy to care for but prone to scratches. Laminate fronts are more resistant but feel a bit less high-end.
Josh68 schrieb:
Regarding assembly: I have basic knowledge but no extensive experienceThen it should definitely be manageable with good planning. Make sure to build the cabinets on a solid, level base. Panels joined together can easily become misaligned if not handled carefully.
General advice for assembling PLATSA:
- Work with at least one other person
- Follow the instructions step by step, especially with the connectors
- Use all the supplied brackets and fasteners to ensure the structure remains stable
- For wall-mounted cabinets, thoroughly check the wall fixings multiple times, as they bear the highest loads
Regarding the fronts: lacquer has a very attractive finish but requires more maintenance. Laminate is more durable, and a matte wood finish helps hide scratches well.
