ᐅ Are there any tips for protecting Ikea PLATSA wood surfaces?
Created on: 15 Aug 2023 10:17
Emilegau
I recently purchased the Ikea Platsa wardrobe system and am very pleased with the appearance of the wood surfaces. However, since I want the surfaces to stay looking nice for as long as possible and to be resistant to scratches, stains, or moisture, I’m wondering: Are there any specific tips for effectively protecting the wood surfaces of the Ikea PLATSA furniture?
I’m particularly interested in which types of surface treatments or care products are recommended, whether home remedies are truly suitable or might do more harm, and how to avoid common everyday risks that could damage the wood surfaces.
Does anyone have practical experience or recommendations for proper care and protection to keep the furniture in good condition over time? Any help would be greatly appreciated!
In addition to the previously mentioned advice, I would like to emphasize that furniture should be avoided in areas with excessive humidity or direct sunlight.
Sunlight can cause the surface to fade over time, and moisture can generally damage the structure.
For cleaning, use only a slightly damp, lint-free cloth.
Stains that can be removed quickly (e.g., coffee or juice) should be wiped off immediately to prevent discoloration.
Jensson schrieb:
In summary, caution is especially advised regarding moisture and mechanical stress, since PLATSA is not made of solid wood.This is an important point. Additionally, it is advisable to avoid placing the furniture pieces directly next to radiators or very warm appliances, as the material can also be damaged by constant heat.
Specifically for Platsa, I recommend against using furniture oils or waxes, as these are not designed for veneer or laminate surfaces and can lead to stickiness or discoloration.
I am familiar with this issue, as I have only recently had a PLATSA unit myself, and at first, I was quite unsure how delicate the material really is. Over time, I have become more confident and have learned:
- Small scratches are almost inevitable, but they should be avoided, for example by not handling the surface with sharp objects.
- I always keep at least one damp cloth and one dry cloth ready when dusting or cleaning the furniture.
- It is also reassuring to know that you don’t need to re-oil the foil surface, but just keep it clean and dry.
Ultimately, it is a combination of careful handling and regular, gentle cleaning.
Oh yes, I’m also a fan of PLATSA! And you can really protect the surface well if you pay attention to the small details. I recommend:
- Felt pads under vases, decorations, or appliances
- Avoid placing sharp-edged items directly on the surface
- Do not use overly wet cloths
And if a small scratch does occur: don’t worry, it happens to everyone. Often it’s less noticeable if you regularly dust and clean the furniture! Keep it up, everyone!
Thank you very much for all the valuable tips so far; they have been very helpful to me!
I am also interested to know if anyone has experience with specific brands of cleaning agents or furniture care sprays that are specially designed for melamine-coated furniture.
I often read that some products might leave residues or cause discoloration over time. Therefore, a recommendation for a product that can be used without any concerns would be really great.
Or should the focus mainly be on water and mild dish soap?
Regarding product selection:
I mainly recommend cleaning agents that are specifically designed for melamine-coated furniture or plastic surfaces. These contain mild formulas without abrasive substances or waxes.
- Universal furniture cleaners with a pH-neutral formula work well.
- Avoid wax-based polishes on laminated surfaces, as they can leave sticky residues and cause discoloration.
In practice, simple solutions like microfiber cloths dampened with water are usually the most effective and safest option.
