ᐅ How can I repair damaged wooden parts of Ikea PLATSA furniture?
Created on: 15 Jan 2020 09:13
majachen
majachen
15 Jan 2020 09:13
I have some damaged wooden parts from my Ikea Platsa system here. Unfortunately, the damage is quite significant – there are broken corners, surface scratches, and some chipped edges. Since I would like to restore these parts, my question is: How can I repair or reconstruct these damaged wooden pieces as accurately and durably as possible?
It is especially important to me that the surface texture and color are largely preserved or at least well restored, as otherwise the repair attempt becomes immediately noticeable. Are there any proven methods for filling and restoring the decorative veneer, or could replacement parts from Ikea’s service be the better option?
I look forward to your experiences and tips!
Ianlau
15 Jan 2020 09:46
Hello majachen,
Your question is very well formulated and shows that you understand the challenge well. Ikea PLATSA units usually consist of wooden carcasses with a veneered or laminated surface, which makes repairs a bit tricky.
Basically, there are two approaches:
- For minor damage such as scratches or small dents, wood filler or special repair kits that can be color-matched are helpful. After drying, you should lightly sand the area and touch it up with furniture markers or paints in matching colors.
- For chipped edges where the decorative laminate is missing, applying self-adhesive foil or a thin veneer patch is possible, but it is often difficult to match the exact color tone.
Spare parts directly from Ikea are unfortunately rarely available, as PLATSA is intended as an affordable, replaceable piece of furniture. Sometimes it makes sense to replace damaged parts completely, especially with major breaks.
If you have questions about specific materials or want a step-by-step guide, I’m happy to help!
noge58
15 Jan 2020 10:05
Hey majachen, great that you want to start the repair! 🙂
I find fixing furniture really enjoyable, and with PLATSA you have a good chance of restoring the look almost perfectly. I’ve had good results using these small repair fillers available in different wood tones – often they match the warm PLATSA colors quite well.
If you sand the damaged area cleanly and apply the filler carefully, you should be able to smooth the surface afterward with fine sandpaper. Then you can protect the surface with a durable clear lacquer.
Don’t be discouraged, even if it takes some effort. I believe you can do it! 🙂
bente
15 Jan 2020 10:37
Hello majachen,
I completely understand your concern, as I care about damage to my furniture as well. It’s always unfortunate when you really like a piece of furniture and then the surfaces get damaged. I’ve dealt with a similar repair before and found it quite challenging to match the right colors and textures.
Sometimes it can be quite frustrating when the result doesn’t turn out as expected. However, I still believe it’s definitely worth trying, even if it’s not perfect in the end – it’s always better than throwing the piece away.
I would encourage you to take it step by step and not expect too much all at once. Maybe you can also try different repair methods to find out what works best for you.
JUHAU
15 Jan 2020 11:01
Best approach:
- Repair broken areas with wood filler
- Lightly sand after drying
- Correct surface color with matching furniture markers
- Seal with a matte clear varnish
Patching films is difficult, as the difference is usually noticeable.
majachen
15 Jan 2020 11:23
Thank you for the offer! That’s exactly what I need—a kind of guide on how to properly use wood filler, which type of sandpaper works best, and how to achieve the cleanest possible color matching.
I also find it difficult to choose the right filler since the surface is partly very smooth and laminated. Are there specific wood fillers recommended for smooth surfaces that adhere well to laminate?
And what would you do with damaged edges that are quite heavily broken? I imagine simply filling won’t help much because the shape is completely missing.
