ᐅ How can I avoid damage when moving IKEA Platsa furniture?
Created on: 24 Sep 2019 10:17
Luandeo
Luandeo
24 Sep 2019 10:17
Hello everyone, I am planning a move soon and have several IKEA Platsa furniture pieces that I want to transport disassembled. My question is: How can I most effectively prevent damage to the Platsa elements—especially to the edges and connection points—during transport? I am particularly interested in tips on packaging materials, handling during disassembly and reassembly, and general precautions to avoid scratches, deformation, or breaks. Maybe you have experience with the typical weak points of the Platsa series or know tricks for safely transporting these shelves? Thanks in advance for your help!
barle
24 Sep 2019 10:36
Disassemble the Platsa and carefully cushion all parts, preferably with furniture blankets. Store screws and small components in clearly labeled bags. Edges should be padded with cardboard or foam.
kulau
24 Sep 2019 11:09
The Platsa series mainly consists of particle boards with a foil surface, which can be easily damaged if handled improperly. When disassembling, be careful not to overtighten the screws, as the holes for the connectors may enlarge. I recommend the following step-by-step approach:
- Disassemble carefully and as completely as possible to avoid bulky parts.
- Protect edges with edge guards (e.g., foam rubber or edge protectors from a hardware store).
- Textile or bubble wrap can help prevent minor scratches.
- Store screws and dowels systematically, ideally with photos or labels.
- During transport, store the parts standing up if possible to minimize deformation.
- Load and unload with care—especially the front panels are very sensitive.
This way, you can prevent damage early on.
BELLA34
24 Sep 2019 11:45
I always place newspaper or old blankets between the parts and pack the connectors separately in bags. Larger parts can also be well protected using sturdy cardboard boxes.
V
vinli
24 Sep 2019 12:14
It is important to protect the furniture parts from mechanical shocks and avoid scratches when packing. Furniture blankets or thick covers should be used to cover the surfaces. Corner protectors are recommended for edges and corners to absorb point loads. Screws and fittings should be placed in clearly labeled containers to make reassembly easier. During the move, the panel elements should ideally be transported upright to prevent warping of the boards.
Luandeo
24 Sep 2019 14:02
kulau schrieb:
When disassembling, you should be careful not to overtighten screws, as the connecting holes can become enlarged.
Good tip, kulau. Are there any special tools you would recommend for assembly or disassembly to avoid damage? So far, I only have a simple screwdriver and a cordless drill with torque control. Is that sufficient, or should I consider a different approach?
