ᐅ How should the wooden surfaces of IKEA PLATSA furniture be properly maintained?
Created on: 10 Aug 2022 08:27
boradu
Hello everyone, I recently purchased some IKEA Platsa furniture with wood surfaces and am now looking for recommended care tips to keep the materials in good condition over the long term. I am especially interested in which cleaning products are suitable, whether special wood care products should be used, and the best ways to handle everyday dirt and minor scratches. It would also be helpful to know if the furniture should be cleaned damp or dry, and which care mistakes should definitely be avoided. Does anyone have detailed experience or even practical advice on the proper and gentle care of these specific wood surfaces from the IKEA PLATSA series? Thanks in advance!
boradu
10 Aug 2022 16:12
rebufar schrieb:
It’s interesting that many people still like to use oils, even though according to Toril, this can be unnecessary or even harmful.
Thanks, that helps me a lot. Some of my Platsa furniture pieces have veneered surfaces. Therefore, I would like to know if it is important to distinguish between “thicker” maintenance wax and maintenance oil when caring for veneer, and how often such a treatment can be repeated without overloading the surface. I am also interested in simple ways to repair small scratches or dull spots myself without much effort. Additionally, it would be helpful to have an opinion on whether these furniture items should be treated with a special sponge or cloth.
bapar
10 Aug 2022 18:05
A detailed answer to your questions:
1. Oils vs. waxes on veneered PLATSA surfaces:
Veneers are real wood layers over a substrate and are more sensitive than melamine-coated surfaces. Care oil penetrates easily and provides moisture protection, while waxes create a protective layer on the surface. In general, oil is better for refreshment and scratch filling, while waxes are more suitable for protection under heavier use.
2. Frequency of application:
For indoor use and normal conditions, maintenance every 6 to 12 months is sufficient. Too frequent treatments can create layers that are difficult to clean.
3. Repairing minor scratches:
Small, superficial scratches can be easily repaired with a suitable wood care stick or wax. For dull spots, light polishing helps.
4. Tools:
Fine microfiber cloths or special polishing cloths are ideal because they clean gently, do not leave fibers, and do not damage the surface. Sponges with rough surfaces are not recommended as they can damage the veneer layer.
5. Caution with moisture:
Never use excessive moisture to avoid swelling of the veneer layer.
If you want details on any of these points, just ask.
lubla
10 Aug 2022 18:58
You can use a damp microfiber cloth for cleaning; mild dish soap helps with stains. For scratches, wax sticks from a hardware store are useful. Oil? Only for real wood, not for laminate or melamine.
Tommy38
11 Aug 2022 07:19
Hello boradu, to add to the previous explanations: When caring for PLATSA wood surfaces, it is important to carefully check the surface texture. Laminate and melamine coatings are very durable and can be quickly cleaned with a damp cloth. Be sure not to use harsh household cleaners to preserve the protective layer.
For real veneer, be cautious with moisture. Use a soft, slightly damp cloth and dry immediately afterwards. Otherwise, regularly dusting the furniture helps to avoid abrasive particles that can cause minor scratches.
To repair scratches, wood touch-up markers in various wood tones are suitable. Always test first in an inconspicuous area. Small dull spots can be restored to shine with a special furniture polish cloth.
If you are unsure about the exact surface you have, you can do a small test at the edge to see if water soaks in or beads up. This will help you distinguish veneer (soaks in) from melamine (beads up).
CARLA
11 Aug 2022 08:47
For an objective summary: The IKEA PLATSA series primarily uses melamine-coated particle boards, which are quite resistant to moisture and scratches. Regular cleaning with a light, damp microfiber cloth without aggressive cleaners is the best way to protect them.
For veneer surfaces, occasional maintenance with wood oil or wax is possible, but only in moderation, as incorrect or excessive use of care products can cause damage.
Scratches on veneered surfaces can often be minimized with special waxes or wood repair sticks. For melamine surfaces, I recommend gentle polishing with non-abrasive cloths. It is important to always verify the manufacturer’s instructions on site, as PLATSA features different surface variants.
Leote
11 Aug 2022 09:26
A brief conclusion: For PLATSA melamine-coated furniture, I only clean with a damp cloth and mild detergent. Oils or waxes should only be used on solid wood. Furniture touch-up markers are useful for minor scratches. Nothing more is needed.
