ᐅ How do I properly care for the surface of IKEA Brimnes furniture?
Created on: 30 May 2021 09:12
Glafalko
Hello everyone, I recently bought an IKEA Brimnes sideboard and want to properly care for the surface to keep it looking good for a long time. My question is: which cleaning agents and care products are best suited for the Brimnes surface without causing damage or stains? Is it better to use only a dry cloth or a damp cleaning method? I am also interested in whether harsh cleaning products should definitely be avoided and if there are any special tips to consider for this type of material. Thank you in advance!
BOSULE
30 May 2021 12:23
Minor scratches on melamine-coated surfaces, such as those on Brimnes furniture, usually cannot be fully repaired without damaging the surface. In such cases, you can try the following methods:
- Use a furniture repair marker or wax sticks in matching color shades to fill in small scratches and make them less visible.
- Apply the product sparingly and carefully remove any excess material.
- Avoid aggressive abrasives or polishing compounds, as they can damage the protective layer.
These solutions are cosmetic and do not replace a proper surface repair.
U
umberto
30 May 2021 13:02
For Brimnes, simply touch up scratches with a matching furniture marker. This works well for minor damage.
rimole
30 May 2021 13:18
Another option is a polish for plastic surfaces that slightly conceals minor scratches without being too aggressive. Always test it first on an inconspicuous area.
Josan
30 May 2021 14:45
Hello Glafalko, I would like to add: For surfaces like these, maintenance involves not only cleaning but also protecting them from new scratches. It is advisable to use coasters or felt pads under objects to prevent abrasion. Avoid direct sunlight, as it can cause the surface to fade over time.
Additionally:
- Wipe up any spilled liquids quickly to prevent stains.
- Do not use abrasive cleaning tools (such as steel wool).
This will help preserve the appearance for a longer time.
Glafalko
30 May 2021 16:10
That’s a tip I hadn’t considered. My Brimnes is placed close to the window, so I’ll definitely rearrange it a bit. Thanks for the heads-up. Are there specific care products, like polishes or protective sprays, that can reduce fading?
anken
30 May 2021 16:35
Generally, melamine-coated surfaces like those on Brimnes are quite resistant to light. There are no maintenance products that effectively prevent fading. Strategic placement is the best approach. For protection, regular gentle cleaning is sufficient. Try to reduce direct sunlight exposure using curtains or blinds.
