ᐅ How do I maintain Ikea BRIMNES furniture on a daily basis?
Created on: 22 Jun 2024 09:42
potuan
potuan
22 Jun 2024 09:42
Good morning everyone, some time ago I purchased several Ikea Brimnes furniture pieces, especially cabinets and dressers. Since preserving their appearance and functionality is very important to me, I am now looking for well-founded advice on how to care for these pieces on a daily basis.
I am not just referring to regular dusting, but also the best ways to protect the surfaces from scratches, discoloration, or moisture damage. Are there specific cleaners that are well suited, or should I rather use home remedies? What is the recommended treatment for hinges and drawer slides? And are there any other tips I should keep in mind to enjoy my BRIMNES furniture for a long time?
Jukin
22 Jun 2024 10:09
Hello potuan, your question is very well phrased and important to ensure long-lasting enjoyment of BRIMNES furniture.
For daily maintenance, I recommend:
- Wiping surfaces with a soft, slightly damp microfiber cloth to remove dust and light dirt.
- Avoiding harsh cleaning agents that could damage the surface. A diluted, neutral all-purpose cleaner is acceptable.
- Thoroughly drying the surface after cleaning to prevent moisture from seeping in.
To avoid scratches, it is best to use coasters or felt pads under objects.
For hinges and drawer runners, a little silicone spray or specialized furniture oil helps keep the mechanisms running smoothly.
If you have stains or stubborn dirt, you can try a mild vinegar-water solution, but do so carefully to avoid any discoloration.
If you like, I can also compile a list of recommended products for you.
RENMA
22 Jun 2024 10:32
Based on my experience and research: BRIMNES furniture is mainly made of melamine-coated particleboard.
Therefore:
- Avoid standing moisture, as melamine is prone to swelling at cut edges.
- Clean with a damp microfiber cloth without using harsh chemicals.
- Do not use abrasive sponges or cleaning agents, as they can scratch the surface.
- For metal fittings, regular wiping is sufficient; oil lightly if needed, but avoid overdoing it to prevent dirt buildup.
These steps help prevent common damage and maintain the appearance over time.
farGlen
22 Jun 2024 11:15
Simply wipe daily with a dry microfiber cloth. For stains, clean with a damp cloth and mild soap. Do not leave water standing on surfaces. Regularly maintain the fittings with a small amount of oil.
fredle
22 Jun 2024 13:47
I would like to share my experiences here, especially to help avoid common mistakes.
1. Cleaning:
- Remove dust daily or at least every two days to prevent scratches caused by particles when wiping later.
- For deep cleaning: use a mild soapy solution (dish soap diluted in water), never full-strength concentrate.
2. Drying:
- Always dry wipe after cleaning, as BRIMNES furniture is prone to water marks on edges.
3. Avoiding scratches:
- Do not place sharp objects directly on the surface.
- Felt pads under decorations or electronic devices help prevent damage.
4. Fittings:
- Regularly check and tighten screws.
- Lubricate drawer slides lightly with WD-40 or silicone spray to prevent squeaking.
Be cautious with home remedies: vinegar or alcohol can dull the surface or cause discoloration. It is better to use mild cleaning agents.
Dilen
22 Jun 2024 15:02
In addition to the points already mentioned:
The surface of BRIMNES furniture is melamine-coated, which is generally durable but can be sensitive if not handled properly.
For daily care, I recommend the following step-by-step routine:
- Use a dry microfiber cloth for dusting.
- If needed, gently wipe with a slightly damp cloth (water + a drop of mild dish soap).
- Dry the surface immediately to prevent moisture from penetrating.
- Avoid direct sunlight on furniture surfaces, as this can cause discoloration.
Regarding the fittings:
- Use a silicone-based lubricant, not an oil-based one, because oil attracts dust.
- Regularly clean dirt from the tracks with a dry brush.
Finally: Have you noticed if your furniture is placed in a particularly humid environment? This increases maintenance needs and may require specific care.
