ᐅ How should the surface of IKEA BRIMNES furniture be properly maintained?
Created on: 23 Jun 2019 09:17
kufavinHello everyone,
I recently purchased an IKEA Brimnes furniture piece and want to make sure I care for the surface properly so it stays in good condition and does not get damaged. My question is: How should the surface of IKEA BRIMNES be maintained, especially the melamine-coated areas, and which cleaning products or methods should be avoided or preferred to prevent scratches, discoloration, or peeling? Are there any other maintenance tips, such as for minor repairs or regular care, that are particularly important for this type of furniture? Thanks in advance for your expertise!
For the care of IKEA BRIMNES surfaces, it should be noted that these are mostly melamine-coated particle boards.
- Cleaning should only be done with a soft, damp cloth.
- Light dirt can be removed with mild dish soap and water.
- Avoid aggressive cleaners, abrasive substances, or solvents, as they can damage the surface and cause it to become dull.
- For initial signs of wear, it is recommended to use special furniture care wipes designed for melamine-coated surfaces.
Another recommendation is to avoid leaving moisture standing to prevent the particle board beneath the melamine film from swelling.
kauti schrieb:
Avoid aggressive cleaners, abrasives, or solvents, as they can damage the surface and cause it to become dull.Thanks for the precise information. Sometimes I have stubborn stains, for example from candle wax or dried coffee – in such cases, would you recommend a gentle household cleaner, or are there special products for these kinds of residues on melamine-coated surfaces?
Is there an official cleaning recommendation from IKEA for the BRIMNES series that I should follow?
My experience with maintaining BRIMNES surfaces is that precision and care are important. Although the melamine-coated surfaces are relatively durable, they are still sensitive to overly wet cleaning methods or harsh chemicals.
Recommendations:
- Routine: Dust regularly with a dry, soft cloth.
- Cleaning: Use a lightly dampened microfiber cloth with mild soapy water.
- For specific residues like candle wax, first try gently lifting the wax with light pressure—avoid scraping or applying strong force.
- If wax or dirt is stubborn, you can carefully apply warm water to a cloth and press it briefly onto the spot to soften the wax. Then wipe gently.
Avoid:
- Abrasive sponges, wire brushes, or sharp scrapers.
- Solvents such as acetone or alcohol.
I also recommend avoiding prolonged exposure to moisture, as this can cause particleboard to swell.
Do you have heavy usage or specific stresses that put extra strain on the furniture? That way, I could offer more tailored advice.
Recommendations:
Avoid:
