ᐅ How can I permanently fix a squeaky IKEA Metod drawer?
Created on: 24 Dec 2021 09:17
Fuharoun44
Good morning everyone, I have a problem with an Ikea Metod kitchen drawer that has been squeaking continuously for some time. The squeaking occurs when opening and closing and is quite annoying, especially because it’s not just a temporary noise but happens repeatedly no matter how often I use the drawer. My specific question is: How can I permanently and effectively fix this squeaking, taking into account both the assembly and the mechanics of the Metod drawer? It would be great if you could explain exactly which parts might be involved, how to proceed, and which tools or lubricants are best suited. Thanks in advance!
RON57
24 Dec 2021 13:01
I fully agree with kulau; the original sliding elements from Ikea are usually the best choice. Since they are specifically designed for the Metod series, you will have fewer issues with fit.
If you order the sliding elements, make sure to provide the exact product number or model designation (e.g., "Metod full extension 40 cm (16 inches)"), so you receive the correct parts.
One more tip: When disassembling the drawer, take photos of each assembly step. This way, you can ensure everything fits perfectly during reassembly and nothing gets lost.
glamo
24 Dec 2021 13:29
Fuharoun44 schrieb:
Regarding the plastic gliders: Do you have a recommendation on where to best order the original gliding elements? Directly from Ikea? Are there compatible aftermarket parts available, or should one strictly use Ikea replacement parts?
From a technical perspective, I recommend deciding individually: original parts are usually the most reliable solution. Inexpensive aftermarket replacements can help in the short term, but there is a risk they may glide worse or wear out faster. It is especially important to carefully check the condition of the clamping or locking mechanisms of the gliding elements, as deformations there can also cause squeaking.
If you’re handy, cleaning and then applying a suitable lubricant will usually make a significant difference, without necessarily having to replace parts.
A quick note: Use lubricants that are heat resistant and do not leave residues. Silicone sprays or PTFE-based products are ideal.
What tools do you have available? Torx or Phillips screws, perhaps also hex (Allen) keys? This will help recommend the necessary steps.
Mufato
25 Dec 2021 08:16
My tip for a quick diagnosis: Depending on how loud the squeaking is, start by checking the rollers or gliders. Loud squeaking usually indicates insufficient lubrication or the presence of a foreign object. Sometimes, simply applying a drop of silicone oil to the rollers is enough.
If the screws were loose, be sure to tighten them, as they often cause noise as well. If there is dirt inside, clean it thoroughly and then treat with silicone. This usually provides a long-lasting solution.
BEMAU
25 Dec 2021 09:12
For structured troubleshooting:
- Remove the drawer
- Check and clean the runners (both sides)
- Inspect all mounting screws and tighten if necessary
- Check plastic glides for wear
- Lightly sand metal surfaces with fine sandpaper if they feel rough
- Apply silicone spray or PTFE lubricant
- Reinsert the drawer and open/close several times to distribute the lubricant
The squeaking usually comes from metal-to-metal contact or damaged plastic parts. Replacement is only necessary if the sliding elements are completely damaged.
Recommendation: Obtain replacement parts from Ikea to ensure a precise fit with original quality. Use lubricants and tools from a hardware store or general retailer.
This method is proven and sustainable.
Fuharoun44
26 Dec 2021 10:36
Thanks again for all your detailed tips and recommendations! Yesterday, I removed the drawer, cleaned it, and applied silicone spray to the sliding rails. I also checked and tightened the screws on the metal guide. This has made the metallic squeaking much quieter, but unfortunately, it hasn’t disappeared completely.
I suspect that one or two plastic glides are actually worn out, as I can see some slight irregularities on the back of the drawer. Today, I will try to order original glide elements from Ikea, as you suggested.
One last question for everyone: Do you think it makes sense to lubricate the individual parts during disassembly, or is silicone spray alone sufficient? I’m a bit unsure whether oil or grease might damage the plastic.
I look forward to your opinions!
