ᐅ How do I replace damaged IKEA Metod drawer runners?
Created on: 2 Dec 2023 08:14
Annimi
Good morning everyone, I have an issue with my IKEA Metod drawer runners in the kitchen: several are damaged, causing the drawers to no longer slide smoothly and easily. My question is: how do I properly replace defective IKEA Metod drawer runners? I am looking for a detailed guide including information on which parts are needed, how to correctly remove and install the drawer runners, and what to pay special attention to in order to ensure everything works stable and without wobbling afterwards. Thank you in advance for your advice.
U
uslis47
2 Dec 2023 10:37
I can add that during disassembly, the fastening screws are often not immediately visible. It is worth removing the drawer completely and then checking the underside of the drawer bottom for small screws or clips. Be careful not to bend the rails unnecessarily when removing the drawer, as this can make installing the new parts more difficult. A second helper can be useful for reinstallation, especially if the drawer is heavy or large. With patience, the drawer slides can usually be reinstalled quickly.
geralu
2 Dec 2023 11:05
Pull out the drawer and remove all screws from the runners. Pull the glide straight out. Position and securely screw in the new runners. Slide the drawer back in.
Goixkin
2 Dec 2023 11:18
A quick addition: The screws for the Metod drawer runners are usually Phillips head. When installing, make sure the rails are positioned parallel to each other. If you have longer screws, only use the ones recommended by IKEA – screws that are too long will penetrate through the back panel and cause damage.
RENMA
2 Dec 2023 11:43
To add: When completely replacing the drawer slides, an important step is to precisely measure the length of the runners. IKEA offers different sizes for Metod, ranging from about 30 cm (12 inches) to over 60 cm (24 inches). Always order the exact matching model, otherwise the drawer will stick. It is also recommended to thoroughly clean the inside of the cabinet and the drawer before installation to keep everything free of dust and dirt, which improves smooth operation. Sometimes, embedded wood particles can make the problem worse.
Annimi
2 Dec 2023 12:07
pikin schrieb:
When installing, always ensure that the sliders on both sides are perfectly parallel and that the fastenings are properly screwed in to prevent any wobbling.
That makes sense, but what is the best way to check if the rails are perfectly parallel? Should I simply measure the distance at the entry and exit points, or is there a specific method for this?
pikin
2 Dec 2023 12:29
To check for parallelism, you ideally measure the distance between the sliding rails at several points – at the bottom, in the middle, and at the top. The distance should be identical at all points. Additionally, you can use a spirit level to verify whether both rails are aligned horizontally. A simple but very effective method is to insert the drawer as a test and slowly pull it out completely. If it does not stick or run crookedly, the work was done correctly.
