ᐅ How do I replace damaged IKEA Metod drawer runners?
Created on: 2 Dec 2023 08:14
Annimi
Good morning everyone, I have an issue with my IKEA Metod drawer runners in the kitchen: several are damaged, causing the drawers to no longer slide smoothly and easily. My question is: how do I properly replace defective IKEA Metod drawer runners? I am looking for a detailed guide including information on which parts are needed, how to correctly remove and install the drawer runners, and what to pay special attention to in order to ensure everything works stable and without wobbling afterwards. Thank you in advance for your advice.
GOLO42
2 Dec 2023 12:52
Annimi schrieb:
How can I best check if the rails are exactly parallel?
Exactly: An important tip is to take measurements with a precise ruler or caliper, as even small deviations of a few millimeters can cause issues. Measurements should be taken at least at three points along each rail. It is also advisable to check the frame for any warping, which can cause the rails to be non-parallel despite correct installation. If available, you can use a straight edge or a thin board as a reference to check the linear alignment. This is especially important when installing a new metal track—the screws should be neither too tight nor too loose.
U
uslis47
3 Dec 2023 08:16
If you want to order drawer slides loosely from a hardware store or online: Make sure the load capacity is suitable for fully extendable Metod rails. Generally, IKEA parts are designed to support around 16-25 kg (35-55 lbs) per drawer. There are universal slides available, but the fit is less precise, which can significantly affect how smoothly they operate. I recommend using the original IKEA replacement parts – they are specifically designed for the system and make installation much easier.
RENMA
3 Dec 2023 08:48
One more technical note: Metod drawer runners with full extension often include additional dampers or soft-close mechanisms. These should not be damaged and must be carefully installed when replaced. If you buy a completely new track, the mechanism is often already integrated. If you only replace individual components, it may cause functional issues. When in doubt, always replace the entire track set.
Annimi
3 Dec 2023 09:17
Thanks to everyone for the many helpful tips! To summarize, I understand that I should:
- replace the entire drawer slide unit,
- order spare parts that exactly match the model and length,
- be very careful to ensure parallel alignment and proper installation,
- and also take the soft-close/damping mechanism into account.
I will place the order right away and plan to start the replacement sometime over the weekend. If I encounter any specific issues during removal or installation, I’ll be happy to ask again here. Thanks once more for your detailed and well-researched responses!
