ᐅ How can I clean IKEA Brimnes furniture without using harsh chemicals?
Created on: 5 Nov 2022 08:23
Iraklis61I
Iraklis615 Nov 2022 08:23Hello everyone, I am looking for an effective and gentle method to clean IKEA Brimnes furniture without using harsh chemicals. Since these pieces are often made of MDF with a coated surface, I want to avoid damaging the finish with abrasive or chemically strong cleaners. Does anyone have experience or tips on how to best clean this furniture without causing scratches, discoloration, or loss of surface gloss? Which household remedies or mild cleaning products would you recommend? I am also interested in how to safely remove stubborn dirt, such as greasy fingerprints or dust bunnies, without harming the surface. Thanks in advance!
Hello Iraklis61, I have had good experiences with a step-by-step cleaning process that truly avoids harsh chemicals and protects the surfaces of Brimnes furniture. Here is my suggestion:
- Start with a dry, soft microfiber cloth to gently remove dust and loose particles. This prevents scratches caused by coarse dirt.
- For the actual cleaning, use lukewarm water with a small amount of mild dish soap (without harsh additives or bleach). The dish soap gently breaks down grease stains.
- Dip a soft cloth into this solution, wring it out well so it is only damp, and wipe the surface. It should never be too wet, as moisture can penetrate the wood.
- If unpleasant or stubborn stains remain, you can carefully work on the area with a soft toothbrush, also using the mild dish soap and water mixture.
- Afterwards, thoroughly dry the surface with a clean, dry cloth.
Mistakes to avoid include wiping surfaces with too much water or using abrasive cleaners. Alcohol-based cleaners can also damage the surface.
In summary: gentle cleaning, damp cloths, mild products, and thorough drying protect Brimnes furniture from damage. I hope this helps you!
Additional advice:
It is recommended to dust the furniture regularly to prevent coarse dirt from being rubbed in. Dust acts like sandpaper on the surface, especially on rougher areas.
Another tip is to avoid using essential oils or waxes, as these can alter the surface over time and may become sticky.
If you have sensitive spots or scratches, you can treat them with a furniture repair marker – this is not a cleaning method but helps maintain the appearance of the furniture.
It is always important to avoid abrasive cleaners or concentrates containing solvents, as these materials can damage the plastic coating.
Iraklis61 schrieb:
Does anyone have experience or tips on the best way to clean this furniture without causing scratches, discoloration, or loss of surface gloss?The IKEA Brimnes surface is coated with foil, making it water-resistant but also sensitive to solvents. Therefore, I recommend the following guidelines:
- Do not use solvents, bleach, or acidic cleaners
- Use soft, lint-free cloths for cleaning
- Cleaning solution: lukewarm water with a neutral detergent, for example, a drop of pH-neutral dish soap
- For stubborn dirt, use a moderately damp cloth with gentle rubbing; avoid abrasive cleaners
- Always dry thoroughly to prevent water spots
This will keep the surface intact and looking good. These recommendations are based on material properties and manufacturer instructions for similar finishes.
barda6 schrieb:
I usually clean Brimnes furniture with just a slightly damp microfiber cloth and, if needed, a mild dish soap solution.That is definitely a very gentle method, which I also strongly recommend.
Vinlen schrieb:
It is also advisable to dust the furniture regularly to prevent rubbing in coarse dirt.This is very important because insufficient cleaning or using heavily soiled cloths often causes scratches.
Additionally, it is recommended to always wipe in the direction of the grain or surface texture to make the cleaning process as gentle as possible.
If stains do not come off, it is better to clean repeatedly with a mild solution rather than using stronger agents or abrasive sponges. This way, the protective film on the MDF panel remains intact.
